Competition Corsair DHX+ Mod Competition!
Discussion in 'Article Discussion' started by Tim S, 25 Nov 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Ohhh thanks for this competition! I happen to be a CAD guy. Worldwide too! Will see a submission from me.
    Edit: Where can we get dimensions of the existing memory and fins?
  3. Guest-16
    Guest-16 Guest
    We're getting them.
    So far the DHX+ heatsinks are 8mm wide, hole centre point is 4mm from the edge. The end holes are 8mm in, and the centre one is 62.5mm from the end. The screw thread width is 2mm.
  4. Guest-23315
    Guest-23315 Guest
    How long is the actual DHX unit though? I think I might whip something up for this compo,
  5. bubsterboo
    24 Jan 2006
    Center hole being 62.5mm from the edge. The whole unit would be 125mm long.
    Thanks for those dimensions Bindi.
  6. Nexxo
    23 Oct 2001
  7. Hiren
    Hiren mind control Moderator
    15 May 2002
    Great resource Nexxo.
  8. Cheapskate
    13 May 2007
    Multiple entries are disqualified? What if I send one entry with a buttload of designs? I'm a shotgun technique designer.
  9. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    something fun to do over the break from uni.
    I will definitely send in an entry!
    also, thanks for the worldwide competition guys, especially with such a focus on innovation rather than something more simple. this is precisely what bit was founded for (innovation in the modding community).
    :D
  10. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Going to do up a something as well. This should be fun...
  11. slugbug
    slugbug Going Broke Saving Money
    12 Nov 2007
    I'm not that good with graphics apps but I'll see what I can do :)
  12. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    shouldn't that be not instead of no?
    [ontopic] hmmm... this is going to be a lot of fun to design.
  13. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    You'll be getting a headscrewing entry from myself. I hope you like surrealist layouts.
  14. Nexxo
    23 Oct 2001
    More useful viweing angles here.
  15. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    :clap:
    Yay Corsair for doing this worldwide!
    Plus i like the setup of this compo, this way you actually get some degree of control wether you win or not :p
  16. bubsterboo
    24 Jan 2006
    Wondering about that too... What if i want to design a cooler that bolts onto multiple sticks in a motherboard at the same time. And a single stick cooler.
  17. Langer
    Langer Jesse Lang
    24 Jan 2004
    Is this a general contest. Or is it exclusive to BT?
  18. Hiren
    15 May 2002
    Not sure what you mean, but the competition is open to all bit-tech readers. :)
  19. Guest-16
    Guest-16 Guest
    Updated the page with a schematic of the fin-array.
  20. Xtrafresh
    27 Dec 2007
    by the way, i assume that ownership of the designs ends up with Corsair, and we can derive no rights from Corsair actually implementing any of it?
    I mean, i don't mind, but i'm really missing this kind of statement from the terms and conditions...
    Also, will all designs be published afterwards? i'm really curious :) Published by you or Corsair?
Tags: Add Tags
