Thanks guys for all your answers and forgive me if I answer only now, I spent a period very messed up... thanks for understanding So continuing ... the pump is a Laing DDC and will use it with the top Aquacomputer that when I saw him the first time I fell in love right away ... beautiful, elegant and simple. On the upper part there is a steel plate which, with its 2 threaded holes 1/4 GAS, can accept two fittings for the inlet and outlet of the liquid. Other two holes are present on a side that have the same function. I will use the side input/output and, since it the top will in view, I not want to put the classic caps but I will use a plate blind without holes that I made.
With great pleasure I announce a new sponsor: Ybris cooling ... for a WB Balck Sun Extreme and a radiator XSPC RX480, thank Ybris and other new components... For my project the black bracket of WB, though beautiful, does not fit and so I made a new bracket in brushed steel.
Little up... This project started keeping in mind that with two radiators, a normal ATX mother board could not enter and that's why I chose a mATX as the Gene. Continuing with the installation I realized that the Gene is small for me and I began to think about how to insert a ATX. Then I saw on the net the Z77 MPower all black and convinced me. But for to be able to insert I have rotated it 90° with connections upwards and this change the layout of the components inside the case. Well now some pictures... In the meantime I have purchased also the wb for VGA. and other new pieces Let's start with the spacers for the rad. This is for the 360 ... There are two steel shells that will be welded. The two plates are two dime for perfect positioning. Then there is also the one for the 480 rad and it takes the same principle ... These below are other plates for the support of the rad, fans, reservoir and hardware. Finally, a small detail of the back plate of the VGA.
