Case Mod - In Progress CYBERPUNK 2077 O.F.
Discussion in 'Project Logs' started by pccustom, 22 Feb 2024.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    HARDWARE
    CASE COOLER MASTER MASTERFRAME 700
    ASUS ROG Maximus Z790 HERO
    Intel Core i9-14900K
    ROG Strix GeForce RTX® 4080 OC Edition 16GB GDDR6X
    Corsair 96GB (2x48GB) 5200Mhz DDR5
    Asus ROG STRIX 1000W GOLD
    SSD FURY Renegade 4TB PCIe 4.0 NVMe
    COOLING CUSTOM EKWB
    stay tuned....
  2. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    I'm in :naughty:
  3. pccustom
    12 Jul 2017
    Hi guys hardware shots!
    Dot_Kappa likes this.
  4. pccustom
    12 Jul 2017
    Hi guys we start. Creating the LED housing plate, this case has a dual function is a case but also a benchmark houses that can be used as a tester, it has a lot of holes that in my case must be covered, my intention is to build a LED plate with themed graphics.
    I make a cardboard shape to calculate the dimensions that I will then go to use EPR the cut on acrylic.
    Make a cardboard silhouette to calculate the dimensions that I will then go to use EPR the cut on acrylic.
    These 2 panels will be superimposed ..
    adidan, Dot_Kappa, IanW and 2 others like this.
  5. pccustom
    12 Jul 2017
    EKWB component arrived
    I chose these fans the EKWB QUANTUM PULSE
    as well as being beautiful they have a different connection system which I wanted to try is a waterfall which eliminates many centimeters of extra cable. They are connected to each other through these 68 pin cables (power and RGB) only the last fan is connected to the appropriate cable which converts the 8 pins into split 2 cables, the classic 2 fan power points and the 3 ARGB pins which go to the motherboard and to the rgb controller.
    two quantum surface series radiators, interesting feature is that it has inlets and outlets at both ends with significant advantages.
    14mm tubes my favorites
    Moriarty, Cheapskate and yuusou like this.
  6. pccustom
    12 Jul 2017
    working on fangrill
    little rear panel on the case..
    paiting the motherboard tray cover.
    rear case panels
    graphics applied soon
    kim, Dot_Kappa, IanW and 2 others like this.
  7. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  8. Dot_Kappa
    23 Mar 2006
    Panels look like have been laser etch :clap:
    kim and pccustom like this.
  9. kim
    kim hardware addict
    10 Jan 2016
    I agree, that degree of accuracy is just outstanding :jawdrop:
    pccustom likes this.
  10. Cheapskate
    13 May 2007
    I don't know how he does it. If I used vinyl for a paint mask, the lines would be all WOOGLY.
    pccustom and kim like this.
  11. pccustom
    12 Jul 2017
    completing the motherboard tray will be on led.
    completing the rear panels
    Cheapskate, adidan, IanW and 2 others like this.
  12. pccustom
    12 Jul 2017
    mounting fan grills.
    next step creating arasaka laterals frames on radiator
