Scratch Build – Complete ⭐ CYBERPUNK 2077 YAIBA KUSANAGI scratch build handmade SPONSORED HWLEGEND MODDING TEAM #CMWS20Finals
Discussion in 'Project Logs' started by pccustom, 17 May 2020.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    I assemble some parts of the fairing to realize
    I do not exclude adding other parts in acrylic to accentuate the line of the yaiba
    I proceed with the construction of the upper aerators
    then I will insert the slats inside painted in anthracite gray, creating a contrast with the metallic red
    is time to paint some parts, the weather is not favorable, it rains ... but I have to go on
    provisional assembly of fan grill
    I have to calculate the dimensions for the cables inside even if it seems absurd there is little space.
    silver finish on some parts
  2. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Awesome!
    pccustom likes this.
  3. keenan
    keenan Minimodder
    12 Nov 2013
    :jawdrop: says it better than any word can!
  4. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I'm starting to see another work of art :dremel: :rock:
  5. pccustom
    12 Jul 2017
    step back but necessary, I realized that I don't like the side panels anymore they are too protruding and from double pega it widens the internal space a lot and since the temple tightens .....
    I decide to do them again ... youppyeee !!!
    this is the panel ..
    proceed with the realization of the internal slats to emulate the air vents.
    I calculate the thicknesses of the acrylic elements well, i.e. 2 mm for the slats and 4 mm for the thicknesses, everything must fit together perfectly otherwise it's a mess.
    I glue everything ..
    it is always annoying to redo pieces and you lose a lot of time especially if you have to do them by hand like me but the result pays off in the end .. it had to be done!
    once completed, the slightly recessed panels (5MM) will be cut in perfect shape to give a depth effect.
    that's fine!
    as we have already understood this project even if it started with a very specific idea is a work in progress, some unforeseen parts are realized along the way as in this passage.
    I realize that although the fairing is beautiful it is flat, I prepare other external panels that attach to the existing panels to give a depth effect that was missing, these panels will join those already made for the external ones with air vents made previously.
    I use the usual procedure, all by hand, cardboard template, study of the measurements, cut with a manual hacksaw and refinish 80 gr sandpaper for smoothing and 220 gr for finishing. obviously all the panels are unique the measures are taken side by side, because this mod is made entirely by hand and the individual pieces are not mirrored.
    use of two-component fiberglass putty to close the cracks generated by the bending.
    t's time to place them to take measurements for the fixing holes. at first glance I see that they will still need to be finished.
    perfection is not of this world but let's try to get as close as possible .. :)
  6. kim
    kim hardware addict
    10 Jan 2016
    outstanding design :wallbash:
  7. Defyant Mods
    14 Sep 2004
    Perfection :rock:
  8. Cheapskate
    13 May 2007
    You need to use a bike lift. No one off-forum would know it's a computer at this point. :D
    Karrek likes this.
  9. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    This is coming along very quickly, great job on the weathered look, and continued high attention to detail :thumb:
  10. pccustom
    12 Jul 2017
    now guys it's getting serious. preparation of the slats that will be positioned inside the side panels. 2mm thick acrylic interspersed with 4mm acrylic
    painting of the side panels that will hook onto those already made previously
    preparation of the air outlets that will be positioned at the bottom ..
    lots of patience....
    we assemble everything.
    the paint is fantastic but will be worn and YAIBA graphics applied
  11. Defyant Mods
    14 Sep 2004
    That vent work is soo dammm sexy :rock::rock::rock:
  12. Cheapskate
    13 May 2007
    ^ Agreed.
    Defyant Mods and pccustom like this.
  13. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    ^^ Agreed too! :lol:
    Defyant Mods likes this.
  14. Cheapskate
    13 May 2007
    Stack overflow imminent.
  15. pccustom
    12 Jul 2017
    When a problem is created, the solution is a must, but sometimes it happens that the ripiuego proves to be better than the initial idea, as in this case. The fan of the 200 mm coolermaster takes up a lot of space on the back and therefore I don't know where to fix the controller what remains is right, the cables, so how to do? I lack space so I have to create it ... the ek waterblocks controller (I know it has software problems and its sale has been suspended, so we look forward to the new release ...) I place it on a low, I create a crankcase to emulate the oil pan of the motorcycle, we will apply finishing wear and logos at the end, since it needs specific measures I build it from scratch.
    I fix everything with glue and finish with fiberglass stucco to consolidate everything.
    and here it is, primer coats, grouting with metal filler, and when the surface is good enough and smooth anthracite gray coat
    I will also pierce the lower fairing.
    he casing will be hooked from below and will contain the controller and the related rgb and fan power cables ...
    censored_Prometheus_ likes this.
  16. pccustom
    12 Jul 2017
    construction of the partial turbine cover
    added threaded bolts on the master cooler fan for easy installation.
  17. Cheapskate
    13 May 2007
    The fit and finish of that part is perfect, as always. :D
  18. pccustom
    12 Jul 2017
    realization of the last upper front and back cover panels
    I do all the tests on paper when everything is in measure for the folds
    I prepare the acrylic sheet that will be folded, puttyed and fixed to the case with M3 countersunk screws
    bending...
    the second one, back..
    now fixing with fiberglass filler and then for metal bodywork.
    install thermo applicable threaded bolts
    further modification.
    front pannel buttons
    wear application with sandpaper.
  19. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    :jawdrop: :rock:
    Great idea to use threaded inserts with plexi !!
  20. Defyant Mods
    14 Sep 2004
    I'm having withdrawals.... i need my pccustom update fix :rock:
