Scratch Build – In Progress Diesel Engine (ITX / SFF / Console)
Discussion in 'Project Logs' started by ChrisHowell, 1 Mar 2016.
  1. kim
    kim hardware addict
    10 Jan 2016
    absolutely lovely...outstanding, I love the whole concept, besides you are selling it a very honest price, great job sir, may I bother you asking where you ordred those premium shielded riser cables?
  2. Vault-Tec
    30 Aug 2015
    Lovely. You are making me want ITX again. Shame I have nothing that will fit in there !
  3. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    Thanks! :)
    Li-Heat sell the ones I use through ebay.com here: http://www.ebay.com/sch/liheat48/m.html?_nkw=&_armrs=1&_ipg=&_from=
    But you can also get shielded cables from moddiy.com : https://www.moddiy.com/products/Pre...dE-Extension-Shielded-Cable-Riser-(30cm).html
    .....and some very fancy ones made by 3M http://www.digikey.com.au/products/en?mpart=8KC3-0726-0500&vendor=19
  4. stonedsurd
    11 Mar 2009
    v2 looks great and I can live without front USB in such a compavt case. Great job! :thumb:
  5. kim
    kim hardware addict
    10 Jan 2016
    thanks a lot for the links...and :thumb: for your work
  6. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    Is the V2 available in black?
  7. ChrisHowell
    29 Aug 2015
    Custom Case: play3r.net Update
    Another small update. I created a custom orange and white Diesel Engine case for the guys at play3r.net. It was a great exercise to see the flexibility of colour schemes that can be applied to the existing design. Here's how it went...
    You can catch the first article of the case on play3r.net at the following link:
    https://play3r.net/news/the-play3r-itx-project-custom-diesel-engine-case/
