Other Does my hardware work well together?
Discussion in 'Tech Support' started by G0oB, 29 Nov 2010.
  1. G0oB
    G0oB Fresh made Modder
    27 Jul 2010
    Denmark !
    hi bit-tech :),
    I got a little problem, that i need to get solved, sometimes my PC just lagges too "sleep" i dunno what the problem could be,
    im not a big "Hardware-Geek" thats why im asking question + im from denmark, that could explain if i got some baaad english ;),
    ok. now for my setup,
    everything will be taken from "Speccy"
    CPU : AMD Phenom II X4 955 ( watercooled )
    RAM : 8.0GB Dual-Channel DDR2 @ 400MHz (5-5-5-18)
    MotherBoard : ASUSTeK Computer INC. M4N78 (AM2)
    GFX : ATI Radeon HD 5850 ( watercooled )
    PSU: 550W Cosair
    Harddrive : 1. 244GB Hitachi Hitachi HDT725025VLA380 (IDE)
    2. 977GB Western Digital WDC WD10EADS-00L5B1 (IDE)
    this should be around it, i hope someone will be able to help me out, :p
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Well, I'll tell you something that may or may not help; I had the M4N78 ( 1st and 2nd revisions ) in m-atx flavour; neither of them liked a reasonably high-end cpu, both would 'hang' for no reason and totally at random ( often when trying to watch videos or anything which required a bit of cpu power ).
    Do you really only have a 1.2 & 2.9GB HDDs, or should that be TBs?..
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Hungary
    Wouldn't an AM2 motherboard bottleneck a Pehnom 2? Also, IDE hard drives?
  4. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    a:/> format c:
    I'm no expert here, but I believe he's referring to hard drives 1 and 2.
  5. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    Belfast
    Have you overclocked your system?
    Sent from my HTC Desire using Tapatalk
  6. G0oB
    27 Jul 2010
    Denmark !
    nooo it was like 1st and 2nd =) i have a 244GB and a 9xxGB
    No idea =)
    Nope, i havent :), dunno how to, so i rather don't
  7. G0oB
    27 Jul 2010
    Denmark !
    Awww i still need answers :(
  8. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    Reading
    that hardware should be fine.
    Could you try and give a better explanation of the problem. You say it seems to hang? what are you doing when it hangs? does it recover?
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    Fresno, CA
    yeah software end can be trickey.. putting it together is like legos- most people can do it
    check your event viewer and post it back here.. sure someone will get back with a fix
