Scratch Build – In Progress " Dragon Desk" ( build in progress )
Discussion in 'Project Logs' started by Gas_designs, 3 Jul 2015.
  1. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Today I fixed discharges of 2 rad, and the plant ... :thumb:
    Qui lo scarico sotto al desk...
    .... :clap:
  2. Gas_designs
    29 Sep 2014
    Hello guys, now is the time to build the structure, to the desk, stainless steel 35x35mm. :dremel:
    Here the final rendering. :clap:
    These are the rods in stainless steel of 2,20Mt :D
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Nice Project.
    Clean workmanship
    But this a planning error for me.
    And an error which does not comply with clean workmanship.
  4. Gas_designs
    29 Sep 2014
    Why, do you see that you do not like?? :grr:
  5. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    I ve written 4 sentences.
    1- “Nice Project. “
    2-“Clean workmanship”
    3-“But this a planning error for me.”
    4-“And an error which does not comply with clean workmanship.”
    I guess you just read the last two only…
    It's not important.
    Next time . I watch your worklog like this .
  6. Gas_designs
    29 Sep 2014
    Hi boys ... :thumb:
    Today realizable shims between the bottom of the desk, and the top plates.
    The compartment that is formed ( fairleads ) is of 20mm. :dremel:
    Tomorrow it fixed its plates .... :clap:
  7. Cheapskate
    13 May 2007
    Looking great.:thumb:
  8. Gas_designs
    29 Sep 2014
    Now fixed thicknesses to 3 inner plates. :dremel:
    For the moment I drive with double adhesive. :D
    ............. :clap:
  9. Dmitry
    Dmitry What's a Dremel?
    3 Sep 2015
    Excellent work, I wish you success!
  10. Gas_designs
    29 Sep 2014
    Upgrading works::* :dremel:
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Very well executed!
  12. Gas_designs
    29 Sep 2014
    :thumb:
  13. Gas_designs
    29 Sep 2014
    Here is a small angular 30mmx20mm, where they will be fixed and the hidden 2 LED strips ... :dremel:
    Seen from below...
    Now mark, the other two buttons, which will switch on and off, the individual LED ......:D
  14. Gas_designs
    29 Sep 2014
    It starts to go to settle finally the 4 corners..... :clap: :clap: :clap:
    Done. :thumb:
  15. Gas_designs
    29 Sep 2014
  16. Gas_designs
    29 Sep 2014
    Here we are after a break .... :D
    Today I realized support for HD 4TB
    Leaving a space below , for the passage of air::*
    Then begin with the drilling on the plate , for the passage of cables :: * :dremel:
    And there it settled :: *
    Now is the time to fix and drill support of 2 usb3 , I took on Amazon :: *
    And after playing with a small file , here it is how the finished :: *
  17. Gas_designs
    29 Sep 2014
    And finally came the stainless steel structure. :dremel: :dremel: :dremel:
    Now I just have to make 2 holes to fix the wall, with 2 threading bars from 12mm, which will pass the wall for greater safety.
    On the center bar will set you see , at the right height plaque tiltable , rotatable and, where staring at the screen .
    .... :thumb:
  18. Gas_designs
    29 Sep 2014
    Now once took measures start to make a few holes on the bar will go to support the screen ... to fix his plate :: *:thumb:
    And finally fixed plaque ... you see the various holes are being made, to adjust the height of the screen , in case of replacement, with a larger :: *:dremel:
    Finally here it is set :: *
  19. Gas_designs
    29 Sep 2014
    Here we go guys, the final stages .... :dremel: :dremel:
    I begin to assemble the grids, and the fans on the side::* :thumb:
    Then I do a test with the 2 Lamptron::*
    Now I make all electrical connections::* :lol: :lol:
    And now I begin to fill the entire system , with a syringe , filling it up, to bleed the air. :clap:
  20. Gas_designs
    29 Sep 2014
    Some pictures::* :thumb:
    Spotswood likes this.
