Case Mod - In Progress Experiment Nr. 5 (Final pics on page 8)
Discussion in 'Project Logs' started by p0Pe, 17 Feb 2014.
  1. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Glad you like it man:D And you can be sure that I was a happy man when he agreed to do the parts ;)
    Thanks Justin! I am proberly still going to need your help on the entire window system:D
    Looks nice! I just dont have the room for a that large machine :(
    Thanks!
    Thanks man! I am also quite pleased with how small it ended out being!
    Now isn't that a compliment! Thanks man!
    I hope it is spindle based. Every cnc should be spindle based:D
    Small update on the sleeving. Nate George was kind enough to ship me a few samples of the Teleios sleeving, and I instantly new that it would be what I was going to use in the case! Along with his cable combs, sleeving has just gotten so much more fun:D
    First I had to take apart the case to do the wires that came down from the motherboard, and the wires from the harddrive on the side.
    After that I fixed the fans that are going to sit in the pedestal.
    Only needed power wires from one of the fans. If you solder together all 3 wires, you will mess up the signal from the fans, and not get a precise RPM reading.
    Cut to length and sleeved. It is hard, but enjoyable to get the sleeving and heatshrink in place properly in fans. Worth it in the end though.
    Fans finished and ready to mount. Still need some minor parts so that they can be mounted to the pedestal.
    Wires for the 24 pin cut to length and crimped. This took far longer time than I want to admit.
    Worth it though. The original wire was faaaaar to long.
    The aftermatch. Need to clean this up, and get some pictures taken:D
  2. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I'm still lurking in the shadows. :)
    And when pOPe approached me with the drawings for this, I had to jump aboard.
    This project is just amazing! :thumb:
    Cheapskate likes this.
  3. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Now where did my head explosion GIF go...
    Great to see the machining god post again!
    Really nice sleeving, I gotta say.
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    You definitely need a short loom for an S3,I think the longest cable I ran was 12",most where around 9".
    +1 on the sleeve too,lovely stuff indeed.
  5. Nexxo
    23 Oct 2001
    Oh, I borrowed it.
    There. You can have it back now. :)
    siliconfanatic likes this.
  6. Teelzebub
    27 Nov 2009
    Wow same one I have, not had the time to assemble it yet.
    How you getting on with it?
  7. Nexxo
    23 Oct 2001
    How can you have a super-cool CNC machine and not have played with it yet?!?
  8. Teelzebub
    27 Nov 2009
    Yeah I know :waah: still not finished the building work yet.
  9. B NEGATIVE
    8 Aug 2011
    Still £400 shy of the £1300 needed. Iwent with the Kress 1050fme and usb controller so it bumped the price a lot!
    I'm putting more bracing in mine too,as well as making much larger end brackets.
  10. Teelzebub
    27 Nov 2009
  11. B NEGATIVE
    8 Aug 2011
    Ooh,vacuum table...nice.
    I need to look at lube spraying myself with some sort recovery system.
    One step at a time tho....
  12. Nexxo
    23 Oct 2001
    That sounds strangely rude. :p
    (Sorry p0Pe for derailing your log...)
  13. Teelzebub
    27 Nov 2009
    Naughty :nono: lol
    I was thinking of buying a large plastic tray big enough to stand the whole machine in ( available on ebay ) and use a cheap submersible pump like the one's for fish tanks in the tray with a long flexible tube fixed to the cutter, of course the MDF bed would have to be replaced with something that wont soak up the cutting fluid.
  14. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Mate you never get tired of modding
  15. Cheapskate
    13 May 2007
    So Pope's thread is the new hangout? :D
    @Tel - I still haven't heard how the axes are driven.
  16. hanssx2
    hanssx2 Minimodder
    1 May 2014
    Well it is a really chill out zone :D
  17. siliconfanatic
    10 Sep 2012
    Pretty much.
    Ya know tel, I knew you had a badass rig but now you're buying a CNC too? Sheesh. The devil never rests. :D
  18. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Sounds feasible but remember to use a filter. :)
  19. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    And I am glad you did it:D
    Thanks! It also kinda killed my fingers.
    Yeah, I think I cut more than half of the cables away:D
    As long as it is fun, I will keep on doing it:D
    I never mind being the center of attention :lol:
    Just need some nice music:D
    Small update, but an update never the less:D
    Needed to mount the fans to the side of the pedestal. I wanted to mount them so that I could easily take them out and clean it. I also did not want the radiators to get loose if I wanted to take out the fans.
    They sit in place by friction, and can be pulled out if they have to.
    And the spacers used.
    Simple is better:D
  20. KidMod-Southpaw
    28 Sep 2010
    Words can't even...
    I want it!
