Windows fading Audio in Premier
Discussion in 'Software' started by Bust_A_Cap, 25 Jan 2005.
  1. Bust_A_Cap
    Bust_A_Cap What's a Dremel?
    22 Dec 2003
    anybody know how to fade audio in Premeir 6.5?
    I have an audio editing program where you can insert a volume "bar" on the audio track and then you can add dots so that you can drag the line up and down and make it fade in and out REALLY easy....anybody know how to do this is in Premier 6.5?
    Thank you!
  2. wilco
    wilco What's a Dremel?
    30 Aug 2003
    I don't have Premier, but look for a feature called "Volume Envelope" or "Envelope Editing." If Premier follows the conventions of Adobe Audition, there will be a little button in the toolbar with a tiny picture of a jagged line with white boxes (or handles) on it.
    -Wilco
  3. Yelrad
    Yelrad What's a Dremel?
    30 Dec 2004
    I Have Preimier And I Am Trying to firgure it out to i use Affter Effects too so i dont know everything about each still learning i know ALOT about vegas 4.0
