Case Mod - In Progress Falcon Northwest Revival
Discussion in 'Project Logs' started by maestro0428, 14 Apr 2012.
  1. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    USA
    So i am constantly looking for new interesting cases to build my pcs in and happened upon this case on eBay. It is the actual case is the photo. Its a beautiful Lamborghini yellow, I don't know whether it is Giallo Fly or Superfly Yellow. Anyway I scooped it up for a song considering how much paint work is by Falcon Northwest. The case is in excellent shape with only a couple of hiccups. As it is so old it only excepts 80mm fans. So do I dare cut the case for larger 92 and 120mm fans or do I replace the old Coolermasters with new Panaflo 80mm? The other problem is that the door is so shallow that a fan controller (with knobs) won't fit. Hmmm.
    Heres a parts list, yeah, its not super high end, but bring whatcha got right? This is all coming out of an old Dell XPS 510 modded for ATX mbs. I like that case, just time for something new.
    AMD 965BE @ 4.0ghz
    Asrock Deluxe 4
    Adata Extreme 8GB
    Sapphire Xtreme 5830
    4 hard drives
    Corsair 650w psu
    DVD burner, etc. etc.
  2. dbradford32
    dbradford32 What's a Dremel?
    22 Aug 2010
    Mod the crap out of it! I personally would still add a fan controller, but make holes in the front door to access them when it is closed. Next up, bust open the shell, add a few 120mm fans, but add only silent fans. From there, go with a window on the side, and keep it along the lines of the lambo yellow. Maybe make the doors hinge in such a manner, that it would keep with the lamborghini theme, also. The possibilities are endless! Great cases, also! :)
  3. Guest-23315
    Guest-23315 Guest
    That's a Coolermaster ACTS-201 or the like if I remember correctly.
    Easy peasy to bung a 120mm exhaust fan in the roof. Look at some of the Wavemaster mods as the chassis internals are identical IIRC
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    In the woods, AL
    Use a reversed fan controller-put in backwards in the end of the bays and adjust it from the inside.
    I want to see a total restore, no cuts for fans, just work with the case and the fans available today and see how it works. I loved that case, and I haven't really seen a mod where 120s were put in one I liked.
    Also, I like your taste in cases. I'm modding a boutique case as well. Now that we're finally able to get our hands on them, there are some wild mods being done.
  5. maestro0428
    24 Jun 2010
    USA
    I think I want to leave the exterior stock looking. I might get some 80-92mm fan adapters so there is more airflow. Hopefully it will be enough cooling. Pics coming soon.
  6. maestro0428
    24 Jun 2010
    USA
    Pics of the case as received
    Here are a couple of pics with the old dvd rom, psu, floppy, cables, etc.[​IMG]
    -maestro
  7. jhanlon303
    7 Sep 2006
    Box under a Bridge, Iowa
    That is one seriously blank canvas to mod. Really nice case. What do you have in mind?
    john
  8. maestro0428
    24 Jun 2010
    USA
    Uh oh my heatsink is too tall for the case![​IMG]
  9. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    Gomel, BY
    =:dremel: :)
    send from my BLADE via tapatalk
  10. Guest-16
    Guest-16 Guest
    The 201 was sans-door, whereas the 210 was with full glass door. I'm not sure what the half-alu door code is.
    Anyone remember it?
  11. KayinBlack
    2 Jul 2004
    In the woods, AL
    No, but I do remember that PSU, Enermax Noisetaker. I miss mine, but my Delta works much better.
  12. maestro0428
    24 Jun 2010
    USA
    Actually the case is the coolermaster atc-110. And yep the psu is an enter max.
    Guest-16 likes this.
  13. Guest-16
    Guest-16 Guest
    Ah 110! I was searching 210. :duh:
    You win, Sir!
  14. Guest-23315
    Guest-23315 Guest
    Coolermaster used to make some absolute beaut cases...
  15. maestro0428
    24 Jun 2010
    USA
    True, I've owned a couple now.
  16. maestro0428
    24 Jun 2010
    USA
    So I found a 80-92mm fan adapter in one of my parts bins. I hooked that up to a Vantec Steatlh 92mm fan and attached it to the rear exhaust port. I have another adapter to go with the other 92mm Vantec Stealth I have for the roof of the case on the way from Performance-Pcs. I actually left the stock 80mm Coolermasters at 12v which is what they were from the factory and those things are damn loud. I cannot imagine trying to live with a pc this loud. Out they go now for some quieter ones or if I can fit it, a 120mm fan. Now that I had to put the stock heatsink back in that is too loud too...for some reason its running at 5113rpm?! Ugh.
  17. maestro0428
    24 Jun 2010
    USA
    So I need a new cpu heatsink. Can anyone recommend a good lower profile AMD cooler?
    Thanks.
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Sisak,Croatia
    Go for Thermaright Samuel 17 or Scythe Samurai.
  19. maestro0428
    24 Jun 2010
    USA
    I also have to get rid of this. Someone tried to scrape it off. Too bad, probably had original spec on it.[​IMG]
  20. maestro0428
    24 Jun 2010
    USA
    Scythe Samari is only 35 bucks here in the US. That may be a good choice. Any other heatsinks come to anyone's minds? Damn, my Xigamatek worked great at 4 ghz. Now its just a paper weight.
