Cooling First time water cooler
Discussion in 'Hardware' started by stonedsurd, 7 Apr 2009.
  1. Krikkit
    21 Jan 2003
    Have you looked through the useful WC links? There's a fair few shops listed there, and although they might not all be there, at least one should carry what you're after. :)
  2. stonedsurd
    11 Mar 2009
    Aha!
    Great list there, thanks!
    You've been really helpful Krikkit :)
  3. Krikkit
    21 Jan 2003
    Just updated the whole list, everyone should find that all links work. If you do find one that dies, either post in the related thread (linked in the first post in there) or PM a mod. :thumb:
    Stonedsurd: I had a lot of help through guides etc when I first WC'd, it's nice to give back to the community!
  4. stonedsurd
    11 Mar 2009
    Thanks! I have some work, will get to proper trawling in a while.
  5. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    I've had very good luck with both Frozen-Cpu and Performance-pcs, but I've found that PPCs has just about anything you could ask for as far as watercooling parts. Both highly recommended, though:thumb:
  6. stonedsurd
    11 Mar 2009
    Thanks Fisher. I guess I'll buy most of the stuff over the coming week.
    Still can't find a place where I can get the DDC + top together. :p
    Guess I'll have to flex the ol' creative muscles again!
  7. stonedsurd
    11 Mar 2009
    Ok, so I emailed Alex at PTS (great guy, very quick and polite! Not to mention patient:thumb:) and he said the XSPC top + DDC is better than his old DDC top combo. So I've settled on that. Now for the EPIC confusion - there are 2 DDCs listed, one of which seems to have better specs but is noisier.
    Would either of them cut it for a loop with the following:
    1 CPU block (heatkiller 775)
    1 GPU block (undecided, either MCW60 or DTek v2)
    1 MCR220 QP
    1 MCR320 QP
    Thanks again.
  8. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    This is a good labs test of the restriction caused by each type of tubing.
    http://www.xtremesystems.org/forums/showthread.php?t=147767
    CPU: Q6600 G0 (Lapped) @ 3.5GHz (438x8 )
    COOLER: TRUE Black (Lapped) + Sunon Denki 'Big Boy'
    MOBO: Asus P5Q Deluxe
    RAM: 4x1GB OCZ Platinum PC2-6400 1052MHz 5-5-5-15
    GFX: 4870X2 -- Samsung 2493HM 24"
    HDD: Velociraptor 150GB -- 3 x Spinpoint HD501LJ 500GB 16MB
    SOUND: Logitech Z-5500 -- X-Fi Fatal1ty
    OTHER: Antec P180 -- Enermax Infiniti 650W -- Vista 64-bit
    3DMark06 = 19000 -- Vantage = E26000 P14000 H10100 X7400
    ModMinded and stonedsurd like this.
  9. stonedsurd
    11 Mar 2009
    That link was AWESOME! Thanks a lot Frohicky.
    I wanted to go 3/8" ID anyway, but that just reinforced my decision, especially in face of the recommendations from the 1/2" ID brigade. :thumb:
  10. Frohicky1
    16 Apr 2009
    Np :D I can't take all the credit, the guys at WaterCoolingUK helped me out on this point. I'm getting a loop for my 4870X2 later this month, thinking myself of getting 7/16" tubing with 1/2" barbs on their recommendation.
  11. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    All good advice, although I'd personally just go with 7/16" tubing and 1/2" barbs so you wouldn't need clamps or compression fittings. But whatever works, well....works, right?
  12. Frohicky1
    16 Apr 2009
    true true Ambiense :D thats what I'm going for, whill prob get some jubilee clips anyway just to make sure.
  13. stonedsurd
    11 Mar 2009
    I like the look of compression fitting, but thanks for the helpful suggestion :)
    I read that draining is a big pain. Any precautions I should take to alleviate this?
  14. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Having recently switched from American thick-walled 3/8" tubing (10mm ID, 16mm OD) to European thin-walled 3/8" (10mm ID, 13mm OD) for the sake of using compression fittings I can say that it might not be worth it.
    The thinner tubing looks well, and the compression fittings look nice and tidy, but it's much more prone to kinking.
    If you have to make any tight bends inside your case the 16/10 tubing will be easier to work with, despite taking up slightly more room.
  15. stonedsurd
    11 Mar 2009
    Thanks Zurechial, even I'm inlcined towards 10/16mm Tygon for the lack of kinking. I found these Bitspower fittings (link) that say:
    Does that mean they'll work with 3/8" ID (5/8"OD) tubing fine?
    Is Bitspower recommended over Koolance?
    Where can I order hex bolts/screws to go with the rad? should I grab a tap for the screws too, so that I can do all the screws in my case like that?
    What's M3.5, M4 etc?
    :confused:
  16. jhanlon303
    7 Sep 2006
    My current H2O project should probably be considered unique in that I am cooling what is essentially a fanless CPU. I originally went with 1/2 tubing but changed it to 7/16 warmed in hot water and forced over the 1/2" barbs clampless after suggestions from The Langer and E.E.L. My main concern is packaging in a small space and not really flow considerations.
    That pointer to the flow calculations was an excellently done post. Bookmarked.
    john
  17. stonedsurd
    11 Mar 2009
    Thanks John. :thumb:
    Where can I order those hex/allen bolts? Can I order any threading? Because the Swiftech rad comes with M3.5 thread (whatever that is) and I'd like to keep it uniform, so that I can just get one tap and a whole bunch of M3.5 threads for all thee screws/bolts around the case.
    And of course, the one question that doesn't seem to have a clear answer anywhere (at least where I've looked) - Will the MCR220 accept G1/4" fittings? I'm keen on the Bitspower fittings indicated in my previous post, but the specs on it aren't very clear. :(
    EDIT: This calls for a combo :lol:
  18. E.E.L. Ambiense
    26 Jul 2007
    If in the U.S., McMaster Carr is a great place to get socket cap screws (allen screws) online, or many local places may carry them. McMaster has any common size/thread type; either 'standard' or Metric.
    The MCR220, along with many many rads out there takes G1/4 fittings.
    Good luck! Let us know if you have any other Q's.
    stonedsurd likes this.
  19. stonedsurd
    11 Mar 2009
    You sir, are a scholar and a gentleman.
    Thanks very much! :thumb:
  20. E.E.L. Ambiense
    26 Jul 2007
    Not a problem, man!
