Found the problem with my Asus Rampage IV Extreme Not booting into windows.
Discussion in 'Asus UK' started by Guest-44432, 1 Apr 2014.
  1. Guest-44432
    Guest-44432 Guest
    I don't think I have any warranty left on this, but considering I'm always very careful with my components and installing them. I was a bit gutted to see the pin bent to the top PCI-E slot.
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Athlone,Ireland
    Can it be fixed? That's a pain.
  3. Guest-44432
    Guest-44432 Guest
    No, as the pin will snap if you bend it back. If I was running a single Gfx card, then I would turn off that PCI-E slot and use the other x16 slot as the board will still work fine. :)
  4. jinq-sea
    15 Oct 2012
    London, UK
    You might be lucky if you try and straighten it, I have had success with a couple of LGA CPU sockets over the years :)
  5. Guest-44432
    Guest-44432 Guest
    Well after an hr of trying all sorts of tools (Hair clip, watch strap pin etc.) I managed to unbend it, but a bit did snap off. It's back in it's original slot, but not sure if it will make a connection to the PCB terminal on a gfx card.
    I can't test this out, as I have no spares, and my current rig is all watercooled, so I'm not planning on stripping it down, until my new case arrives. :)
  6. jinq-sea
    15 Oct 2012
    London, UK
    You might be lucky :)
    It would be a shame to waste such a good board for something like that.
  7. Guest-44432
    Guest-44432 Guest
    Well, we will see. I might just chuck it on Ebay as I have no box or anything for it, as my ex chucked all that away!
