Planning frequensee - Quad CPU Signals Analysis Machine
Discussion in 'Modding' started by InitialDriveGTR, 13 Feb 2013.
  1. InitialDriveGTR
    InitialDriveGTR What's a Dremel?
    13 Jan 2012
    Been a bit since I posted here, but figured I'd share what I have been working on since my last build.
    I'm going to use these four 8-core Xeon X7560's to perform RF data analysis.
    Using from 5 - 10 usb tv tuners acting as software defined radios, I can record and process a lot of data, really quickly. Part of the antenna array is hung on the back side of the case. Using the CUDA libraries from NVidia, it will have the ability to off load work from the CPUs to the GPUs. There's some other functionality that I have planned that I don't want to mention yet until it's further developed. Two computer science majors with access to a Dell R910 with the same four CPU setup are assisting me with the software setup for the time being. From today until mid-May I will be collecting parts for the build, the four Xeon X7560's I already have, which I think is a pretty good start. I will start sending out orders to have parts machined once I get back to work after this semester.
    It will be using two Aquacomputer 360 Airplex Radiators, in addition to a 240 Airplex Radiator. Two D5 pumps (also by aquacomputer) will push the water through the channels that are integrated into the case.
    Each CPU will have its own waterblock, and the the two GTX690's will also have full aquacomputer waterblocks (take the hint on aquacomputer here.....)
    These renders are all of an unfinished project, but expect updates every couple days. I want this design at the point where I can submit the model file to the machine shop and just wait for the parts to show up, by May.
    An older render from google sketchup.....
    Link to my thread: http://www.overclock.net/t/1274057/build-log-frequensee-quad-cpu-signals-analysis-machine
  2. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    32 cpu cores. Homina homina homina
    And still your gonna do it in style :thumb:
    May I assume that that overhang is for ducting air from the rad?
  3. Cheapskate
    13 May 2007
    This sounds and looks promising.:D
