Modding Front Panel IO Components
Discussion in 'Modding' started by rogergamer, 1 Nov 2015.
  1. rogergamer
    rogergamer What's a Dremel?
    3 May 2015
    Hello everyone,
    I was just wondering what components modder usually buy/use for the front panel IO of their scratch builds.
    I recently purchased this cable:
    http://www.lian-li.com/en/dt_portfolio/pw-in4iah85at0/
    for my scratch build and it set me back 40 dollars, are there other cheaper or more practical options?
    thanks!
  2. rogergamer
    3 May 2015
    double post
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Maybe something like this
  4. rogergamer
    3 May 2015
    ah ok, the layout looks bad IMO, but then you can't beat the price
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Another option is to pick up a cheap used tower case and use the IO from that.
  6. rogergamer
    3 May 2015
  7. mal
    mal What's a Dremel?
    20 Nov 2012
    Case Labs has a few options. This one is $20.
  8. rogergamer
    3 May 2015
    their usb and audio combo thing is still 40 dollars though
  9. teabag
    teabag What's a Dremel?
    17 Nov 2015
    Depending on the case, wouldnt it be cheaper to buy a new case?
  10. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    Scrap the mic and headphone ports and just buy yourself a USB internal cable with screw mounts and a power button cable and momentary switch. Thats what have done for scratch builds. Yeah, it takes extra work to figure out how to mount it to the case, but also gives you complete flexibility on the format of ports and layout. That lian Li cable is well overpriced.
    http://www.amazon.com/StarTech-com-...0734176&sr=8-21&keywords=usb+3+internal+cable
    http://www.amazon.com/uxcell-Button...d=1450734280&sr=8-13&keywords=power+switch+pc
