Build Advice Future Workstation Build ( Please Advise )
Discussion in 'Hardware' started by Ricky_005, 15 Jul 2010.
  1. Ricky_005
    Ricky_005 What's a Dremel?
    30 Jun 2010
    Components list for my Future Workstation/Gamingstation :rock:. Any Suggestions or Comments welcomed.
    Build is for Mainly Cad/Video Editing/Website Development Work :hip: & FPS Game Play Second
    Will Not be Overclocked :nono:
    Stability is Important overall :thumb:
    Intended Lifespan 5+ Years :eyebrow:
    LIAN LI PC-B10 Black Aluminum ATX Mid Tower Computer Case
    $219.99
    CORSAIR HX Series CMPSU-750HX 750W
    $139.99
    MSI Big Bang-XPower LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    $299.99
    Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor
    Model #:BX80601930
    $289.99
    Enzotech Extreme-X Rev.A 120mm 2 Ball CPU Cooler
    $41.99
    Mushkin Enhanced Redline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
    Model #:998805
    $199.99
    EVGA 012-P3-1475-AR GeForce GTX 470 (Fermi) SuperClocked+ 1280MB 320-bit GDDR5 PCI
    359.99
    ASUS Xonar DX 7.1 Channels PCI Express x1 Interface Sound Card
    $79.99
    Corsair Force CSSD-F120GB2-BRKT 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
    Model #:CSSD-F120GB2-BRKT
    $309.00
    Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
    Model #:WD1002FAEX
    $94.99
    Sony Optiarc CD/DVD Burner Black SATA Model AD-7261S-0B LightScribe Support - OEM
    Model #:AD-7261S-0B
    $22.99
    Logitech G110 Black USB Wired LED Backlighting Gaming Keyboard
    $69.99
    Logitech G500 10 Buttons Dual-mode Scroll Wheel USB Wired Laser Gaming Mouse
    $59.99
    Microsoft Windows 7 Ultimate 64-bit 1-Pack for System Builders - OEM
    $174.99
    Subtotal: $2,392.8 Pricing from NewEgg
    A few Notes
    MSI Motherboard For having all x16 slots, USB 3.0 and SATA 3.0
    The low lantancy of the ram should mean quality chips. I plan on increase the timing to ensure stability. From 6-8-6-24 to 8-8-8-20 Lower Voltage Also:confused:
    Enzotech Extreme-X CPU Cooler so there's a down draft cooling the motherboard Components.
    Would love to have a Corsair Force F240 SSD drive but the Cost....:jawdrop:(Maybe a Future Upgrade later.)
    WD 1TB drive for Storage/Backup..... Would Rather have a 7,200 Rpm SAS Drive but would require a SAS/SATA Controller Card also $$$$$
    EVGA GeForce GTX 470 ...... Its a hot potato I know ....... but overall Nvidia write the best drivers! In short should = Stability I plan on underclocking it back down to stock speed to lower Temp. There should be extra cooling for the OC version.
    The sound card I'm still sorta not sure about....:confused:
    Sony Optiarc CD/DVD Burner ( Has NEC Chip )
    Logitech Keyboard and mouse ....... Hope they are good for Work as they are at Play!
  2. Ricky_005
    30 Jun 2010
    Forum must be dead!
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Why do you need 4 Pci-express slots if you are running one card.And also why the 470? is it for cuda?
    I would go for the 5870 if cuda isnt needed or else the 460 if it is needed.
    Also i would go for The Titan Fernirr.
    Why Ultimate why not go for pro?
    Get what ever dvd drive is cheapest.
    Swap the PSU out for the Corsair HX850w
  4. Ricky_005
    30 Jun 2010
    Next :geek:
