12850 at 5.3 with some scary voltages. I bricked my pants and gave up after the UEFI started not behaving the same. I don't want to play anymore! But... I believe the top of the 2500ks need to change Now I can finally play some games!!!
Thanks! I guess it'll last as long as you got kicked takes to notice and accept the challenge. I suppose. Faster memory would do it. Or even more mental volts... But the .1ghz were giving diminishing returns.
So here's my M18X R2 results. OC to 3.9GHz (Maximum settings in current bios.) 12133 http://browser.primatelabs.com/geekbench2/824538
Pook; it looks like you missed one at some point. I'm busy truing to remember what settings I used to achieve these results, however. (This was back on my 990FXA-UD3)
Bwahaha~ I could do it on this board, but I'd need to watercool again. Too much effort. Pook; it was something in the reigon of 268 FSB on crazy voltages under water, 5040mhz CPU and 1599-1601mhz memory. (19.5x multi on the CPU.) Rest of the information in Geekbench should show everything else.
It's just teh clock speed is wrong.. everything else is fine. If you reckon a 2g8 FSB I can work it out though. I'll sort it tomorrow.
Whoops. I must've derped with my maths somewhere. It's 258 on the FSB. I remember I didn't touch 260, so 258 sounds like it, I was at the absolute max the NB on that board would let me go. As is; The NB on the Crosshair is happily purring along a 2640 without any voltage bumps at the moment, so it looks like I could happily push a lot more out of this board under water. Perhaps when I have money, and after GPU upgrades.
