geforce 250 for £85
Discussion in 'bit-tech Folding Team' started by Thaifood, 27 May 2009.
  1. Thaifood
    Thaifood Minimodder
    24 Apr 2009
  2. GoodBytes
    20 Jan 2007
    Montreal, Canada
    For a renamed Geforce 8800GT? I don't think so.
  3. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Wakefield
    They have 128 sps not 112. They are pretty good folders 5000+ ppd
  4. Viper355
    Viper355 What's a Dremel?
    23 Apr 2009
    Scotland
    isn't GTS 250 re-branded 9800GTX+ which is 8800GTS 512 ?
  5. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    oh good point... wasnt there a 8800gtx? or was the 8800 gts the fastest?
  6. GoodBytes
    20 Jan 2007
    Montreal, Canada
    GTX is more expensive but is worst in all aspect than the much cheaper version that came out later called The GT.
    The GS was the light version of GTX released before the GT.
    However, a second generation of GS came along which is a light version of the GT and not the GTX.
    What a mess, I know!
    The 9800 GTX is a renamed 8800GT with tripe SLI support. Then the 9800GTX+ is the same, just using a smaller die, making produce a little less heat, but performance gain was minimal. The 250, is the 9800GTX+ on a smaller board (in length), and uses 10W less on average. There are other differences but the performance is still close to it's predecessor which is close to the 8800GT.
    The way I see it, is a laptop that gets re-released with added USB ports on each version.
  7. MrGumby
    27 Apr 2009
    Wakefield
    No the 8800gt has less stream processors. The 8800GTS 512 is the card similar to 9800gtx and 250gts.
  8. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    so those boards arent worth the $$ then?
  9. MrGumby
    27 Apr 2009
    Wakefield
  10. GoodBytes
    20 Jan 2007
    Montreal, Canada
    Aye Aye Aye..
    Doesn't mean you have more of one thing that it's necessarily better. I mean YES it is better but insignificant level in real world result.
    You are better to go with the GTX 260, 275 then a GTS 250.
  11. MrGumby
    27 Apr 2009
    Wakefield
    Yep all come down to price vs performance. And for me temps and noise. Them 8800gs are relly good value for £35 a piece. Avg around 3200ppd. Im interested in seeing what gt300 series does in terms of performance and what it may do to the price of the older cards.
  12. Unicorn
    25 Jul 2006
    Northern Ireland
    Correct, and the 2x that I have are awesome overclockers with the right cooling. They run close to the same spec as 9800's ;)
  13. Paddy4929
    Paddy4929 NangO-Gamer
    24 Apr 2009
    I got a 250GTS. It's not bad for folding and only requires 1 6-pin connector which is a bonus for me personally.
