News GNU/Linux hit by glibc security vulnerability
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Feb 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    glibcgate! glibcbleed! glibcoodle! Is there a mediatic name for this yet?
  3. Gareth Halfacree
    4 Dec 2007
    If there isn't, I'm putting 'GlibCrack' in the hat.
  4. jewelie
    jewelie Ancient geek, newbie to BT
    3 Jun 2015
    Hmmmm.... Is this only an issue using SSH or does the glibc bug propegate in such a way that it causes practical security issues on all glibc-based devices, whether or not SSH is installed? I'm thinking particularly about routers/modems in particular
  5. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    routers are especially a problem as they are rarely updated or never (lack any updates)
  6. Gareth Halfacree
    4 Dec 2007
    If something uses glibc's DNS resolution, it's vulnerable. Thankfully, there are mitigations: it's not easy to exploit, it's even harder to exploit in a manner that executes code rather than just crashes the system, and most embedded devices don't use glibc 'cos it's a beast. While there *are* routers/firewalls/etc that use glibc, they're in the minority; most use uClibc, 'cos it's smaller. Likewise, anything that has its own DNS resolution code, even if it uses glibc for everything else, is safe.
    You can also protect a system without upgrading glibc (if you want to, though the proper fix is of course to upgrade glibc) by filtering DNS queries with a firewall or dnsmasq or similar.
