Scratch Build – In Progress God of Machines
Discussion in 'Project Logs' started by nhenhophach, 8 Feb 2017.
  1. nhenhophach
    nhenhophach Bit-tech
    16 Aug 2007
    Hi, Everyone,
    My project entry for the Cooler Master contest 2017, named God of Machines.
    This is a small 5-pc-in-1 system.
    My design it will be use for Lanparty Gaming Teams (Dota 2 or LOL team), Internet Cafe or small companies  that do not have space for computer case.
    I also got sponsored (hardware parts) from:
    Gigabyte Vietnam.
    Plextor Vietnam
    FSP TECHNOLOGY INC.
    Apacer Technology Inc.
    Intel Vietnam.
    And I wanted to send a big thank you to all those companies for their support on this Project
    Like i say above is a 5 pc in one systems so i needed a chassic that have space for all 5 motherboards and the other components. Hence i put them in the CUBE-Shaped chassic
    Designed using Solidwork
    The stand
  2. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That is a pretty nice idea. Looking forward to it.
  3. Nexxo
    23 Oct 2001
    I'm liking the look of that!
  4. Cheapskate
    13 May 2007
    OK, you made me put my cube case in the WAY BACK of the closet. :lol: All hail the nhenhophach cube. That thing is awesome.
    5 pcs... This thing is Death-Star sized, isn't it?:eeek:
  5. nhenhophach
    16 Aug 2007
    Continue,
    All parts CNC is done.
    Aluminium 6061.
    3D:
    Real
    I start assembly the chassic.
    And I need a very strong stand.
  6. nhenhophach
    16 Aug 2007
  7. storm-83
    storm-83 Minimodder
    7 Nov 2014
  8. kim
    kim hardware addict
    10 Jan 2016
    yes..:jawdrop:, words are hard to find....this is absolutely fantastic
  9. Cheapskate
    13 May 2007
    Delicious. :D
  10. nhenhophach
    16 Aug 2007
    Motherboard tray
  11. AM Modding
    AM Modding What's a Dremel?
    11 May 2016
    Amazing !
  12. Nexxo
    23 Oct 2001
    CNC'd aluminium just makes me feel all tingly. :)
  13. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Yeah,I dig it.
  14. Vault-Tec
    30 Aug 2015
    Fannytastic. A lot smaller than I thought it would be too.
  15. Cheapskate
    13 May 2007
    my vague memory if ITX boards, and a quick measuring of the pic by holding up a ruler and squinting, gives me just under 13 inches on the panels.
    -And your watermark KEEPS spooking me. :lol:
  16. nhenhophach
    16 Aug 2007
    Yes sir, ITX motherboard:D
  17. Impeccable Logic
    Impeccable Logic What's a Dremel?
    9 Mar 2015
  18. nhenhophach
    16 Aug 2007
    Update!
    2 FSP Powersupply 600W AND 2 120mm Radiator Module
  19. nhenhophach
    16 Aug 2007
    Hardwares
    Special one
  20. nhenhophach
    16 Aug 2007
    GTX 1050 DIY WaterBlock
    Fast CNC cooper for GPU and Memories, Top with Acrylic and Carbon Sticker
