Graphics GTX 460 Cyclone in the process of eating it, what should I upgrade to?
Discussion in 'Hardware' started by Mac_Trekkie, 23 Mar 2012.
  1. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Sol system, 4th planet from the sun
    My GTX 460 Cyclone has served me well for nearly 2 years now, and I'll be very sad to see it go bye bye, but the fan is in terrible shape, a blade got snapped off after an unspecified someone (might be me :worried:) accidentally stuck their finger in it while it was running :wallbash:. So It's finally started properly overheating, and I think the fan has bent the axle or something, because a couple days ago it started vibrating worse than ever before even at minimum fan speed, and I'm afraid of it damaging my hard drives or the PCIe slot or something. I was thinking of this beautiful ZOTAC GTX 560 Ti -448 core, since it comes with BF3 and I've been wanting to get that. Otherwise I would have gone with the $10 cheaper MSI Twin Frozr III version. Maximum budget is around $275, hoping to purchase from Newegg.com
    Zotac: http://www.newegg.com/Product/Product.aspx?Item=N82E16814500231
    MSI: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127615
    EDIT: The special bringing it down by about $30 is ending in about 45 minutes, I'm pulling the trigger on the Zotac in 15. Tell me if I'm making a terrible mistake by then!
    EDIT2: Bought the ZOTAC after a few review reads. Anyone care to give me a pat on the head and tell me I did good? :blush:
  2. Deders
    Deders Modder
    14 Nov 2010
    Here and there, mostly there
    Seems like a bargain, how much would that be in £?
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Zotac looks good- you sure you can't get a second hand 580 now for that money?
  4. urobulos
    urobulos Minimodder
    13 Apr 2010
    I would've advised buying a second hand 580 or 570 depending on the second hand pricing on the other side of the pond. But you can't argue with the 448 core 560 Ti especially at anything up to 1080 or 1200p. It's a mighty fine card which can go toe to toe with the 570. And once you add in the money you would have spent on BF 3 it's an even better purchase from a value point. Hope it will serve you well.
  5. Mac_Trekkie
    10 Sep 2011
    It's only at 1200p, and my parents who funded this endeavor wouldn't approve buying a second hand card. Also I don't any other marketplaces besides here, and there seems to be no activity on the american section.
    In GBP, the price would be 170, after rebate 157. I figure I'll overclock it a bit to match a 570, maybe even reapply the thermal paste if I'm feeling adventurous. Unfortunately my 460 is just giving me terribly disturbing noises and vibrations, and I wanted to get it out of my system ASAP. I don't have any spare GPU's laying around that actually work.
  6. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    Get a 680.
  7. Mac_Trekkie
    10 Sep 2011
    I don't have the budget and I don't need a giant brick spewing heat and sucking power while idling when I play my most demanding games at 1200p. Completely overkill and troll suggestion.
  8. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    It's not a giant brick. It's a small brick.
  9. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    North Yorkshire
    For Christ's sake feathers stop spamming! Post reported.
  10. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    All I did was suggest a 680 which I intend to purchase myself when I have enough money.
    The small brick comment was a lighthearted response.
    Hardly justification for getting into an extreme rage.
    I have reported you also for extremely aggressive behaviour and over-reacting.
  11. Tangster
    23 May 2009
    York, UK
    It's pretty good with regards to temps and energy usage. Granted the power draw isn't as low as a 560ti, but the temps are better.
  12. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    I have a couple of liquid cooled 560Ti's for sale now. 1gb MSI.
  13. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Northampton
    Actually, the TDP of GTX 680 is 195W and GTX 560 Ti-448 is 210W, so the new cards are more power efficient than the one the OP bought. That doesn't mean Feathers is right to mention it in every partly related thread though, I'm sure anyone who can afford one has already read about them.
  14. Tangster
    23 May 2009
    York, UK
    I need more money.:sigh:
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    I haven't mentioned it in the headphone thread.
  16. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    USA
    ... nevermind, didn't see you already purchased.
    I would replace the cooler on the 460 and hold out for 660 release.
  17. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    I also didn't see he'd purchased.
  18. debs3759
    10 Oct 2011
    Northampton
    Well, you'd better get in there and rectify it then :)
  19. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    Will do.
    After all, if the guy wants earbuds or headphones he needs a 680 to go with it.
  20. Mac_Trekkie
    10 Sep 2011
    I think I'll quietly abandon this thread to die now.
