Scratch Build – In Progress HDJ Project: DGame -- 31/12 FINAL SHOTS --
Discussion in 'Project Logs' started by Herodj95, 14 Dec 2015.
  1. Cheapskate
    13 May 2007
    Toaster oven, Texas
    Nice and clean.:thumb: Looks like there's some hinge chopping coming.
  2. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Italy
    Thanks Cheapskate! :thumb:
    Yes, also on the other side of the case coming other hinges
    On the other side of the case, there is this metal sheet as you know
    Into the central opening i'm going to insert metal pieces to create the logo of the case
    that's the idea
    and fit temporarily to check the pieces
    ok, now that's all is good, i can proceed to finish off those pieces.
    My idea is to maintain the metal "color" without rust , so i've decided to scratch the metal with sandpaper and apply a glossy transparent coat
    ... Aaaaannndd that's the result! :thumb:
    :rock:
    So, it's all for today... tomorrow i hope to upload other photos ;)
    Bye,
    HeroDJ
    :D
  3. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Italy
    So, i'm back! :)
    Tomorrow's up it's dedicated to painting and assembly!
    For the mod i've choose the Antrhracite black for metal sides and the motherboard tray
    Now the paint is dry and i can see the final effect... I like very much the matt effect, very elegant
    Meanwhile, i have removed the paper tape from the aluminium frame
    With some sandpaper i'm going to clean the aluminium removing glue residues
    When all is ready, i can now assembly all of the pieces
    As you can see into the previous photo, i've already hold in place the motherboard... so let's start assembly also the hardware
    And on the backside, all openings matching:thumb:
    After mounting the motherboard, i'm going to hold other boards (usb/audio and power board)... let's start from the usb/audio board
    With blue tape, i'm going to "mask" the flat cable that connect the two boards
    Next, i've mounted it
    Same procedure to the flat cable that connect the power card. The cable pass under the tray to hide it
    And mounting the aluminium frame....
    After that, i can mount the usb card.. under it, i've applied some tape to isolate the contact from the metal tray
    As you can see, i've also mounted some magnets to stop the sides and lock them when they are closed
    Next, i've glued the power card to the frame
    At the end of the day, that's the result! :thumb:
    So, i'm near to the finish... tomorrow i hope to upload the last photos before the final shots :thumb:
    I hope you like it.
    Good evening,
    HeroDJ
    :rock:
  4. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Odense, Denmark
    Nice execution!
    A little big around the edges, but i guess it's less excessive in real life, than from looking at a photo...
  5. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Italy
    Thanks Storm :thumb:
    The holes matching well, i think that the angulation of the camera mislead a little bit ;)
  6. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Italy
    AAAAAAnd.... here we are with the final UP (before final shots) :rock:
    Let's start with this scrap piece of plexyglass painted with blue spray paint. There are some holes but i don't care because when all is finished they not going to be visible.
    This piece is glued with mastic... is very strong for this kind of gluing:thumb:
    with the tape i hold in place the plexyglass until the glue dry
    Now it's dry
    All is completed, so with rivets i can mount the bulkheads
    Now, with other mastic, i can now glue the logo's pieces on the blue plexyglass
    I love it! :D
    At this point, i can say that the mod is finished.... Tomorrow i'm going to upload the final shots!! :thumb:
    See you soon,
    HeroDJ
    :rock:
  7. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Italy
    Now i can, finally, say... MOD COMPLETEEED!! :rock:
    I'm very proud for the result, the mod looks how i've imagined.... There are the final shots, i hope you like the work :)
    So, finally the mod is completed! :thumb:
    Thanks to all that have followed the worklog. I also wish to all, happy holidays and happy new year :)
    See you soon with other worklogs,
    HeroDJ
    :dremel::dremel:
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Odense, Denmark
    Nice job on the case, looks really good with the different accents on different parts!
    Looking at the pics, i'm going to ask a question i was asked myself;
    How stable is the case? Looks like it could potentially be a bit unstable and prone to tipping over too easily?
  9. arduum
    arduum Minimodder
    10 Mar 2015
    Ru, Saint-P
    Good Job!
    Happy new year ;)
  10. Cheapskate
    13 May 2007
    Toaster oven, Texas
    Awesome!:D All it needs is a little LED to light the blue.
  11. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Italy
    Hi storm, thanks! :)
    The case is pretty stable, the base is 4cm wide. is not much, but i haven't got any instability problem. Anyway i'm already build an U support to maintain the case stable (i'll show you soon)
    Thanks arduum :)
    Thanks Cheapskate ;)
    i don't know, i like it without leds (there is only one led on the power button) but in the future maybe i can insert some
