Development help read txt files
Discussion in 'Software' started by ahug4122, 13 Oct 2004.
  1. ahug4122
    ahug4122 What's a Dremel?
    16 Sep 2004
    i need to be able to put a heap of words in a txt file
    so i can read every line until the end a if the word in the txt file is there then msgbox
    if not end
    does any body no how to do this in visual basics
    :duh:
    i so need this i am doing an prac test soon and i can find any info
    plz help
  2. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    a bit more info, possible an example of what the file will look like?
  3. ahug4122
    16 Sep 2004
    umm
    c:\pop.txt is the file to read
    file contains
    top
    cat
    hat
    popular
    cats
    basket
    i want the inputbox to check if it contains one of the words in this file and if it does then msgbox("password correct")
    else msgbox("worng")
  4. kplonk
    1 Mar 2002
    to get you going creat a project and add a command button
    then add this to the the sub_click for that button
    Dim test As String
    Dim filetext As String
    test = InputBox("enter password")
    'open file
    fnum = FreeFile
    Open "c:\pop.txt" For Input As fnum
    txt = Input$(LOF(fnum), #fnum)
    Close fnum
    filetext = txt
    i = InStr(filetext, test)
    If i > 0 Then
    MsgBox ("your in")
    Else
    MsgBox ("wrong password")
    End If
  5. Hepath
    Hepath Minimodder
    20 Oct 2003
    as an alternative....
    Dim oFSO as New Scripting.FileSystemObject
    set ts = oFSO.OpenFile(filename)
    Dim contents as string
    string = ts.ReadAll()
    dim found as bool
    found = false;
    if (instr(lookfor, contents) > 0)
    found = true;
    or summat like that.....
  6. ahug4122
    16 Sep 2004
    on that frist one yea it works but if i put a string of nothin in the input box "i am in" :wallbash:
    what about reading the file until eof(end of file) and dumping in a array would that work????
  7. kplonk
    1 Mar 2002
    There is another option, you can open the file for random access, and add this to an array, the problem is do you want to match exact words only and full case?
    K
  8. ahug4122
    16 Sep 2004
    yes i dont mind how it works and casesentive would be good
  9. ahug4122
    16 Sep 2004
    IS ANY body going to help me please
  10. djengiz
    djengiz Pointless.
    16 Aug 2002
