Build Advice Help with upgrade
Discussion in 'Hardware' started by Neox010, 14 Jun 2010.
  1. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    Hi all.
    I currently own the pc in the following specification.
    1. Abit Ip35 Pro
    2. Intel Q6600
    3. Corsair XMS2 800 (4gb 2x2gb)
    4. Corsair HX 620 Modular
    5. WD 320GB HD
    6. XFX 8800GTS G92 512MB
    7. X-Fi cheap thing
    Which is housed in an Antec 1200. I play on EVE Online and Star Trek Online, as well as some video editing.
    I would like to replace
    .Motherboard
    .Processor
    .Ram
    .Graphics ( I own a 24" Main ( 1080P res ) and a 20" secondary ( 1680 by 1050 )
    For much more modern variants, I have at the upper limit £700 to throw at this, maybe more if the parts are worth the cost.
    I do plan on pushing the OC a touch so perhaps a warranted cooler would be ideal.
    I hope I have stuck to the rules enough, but I am honestly so far out of touch with today's hardware that I need some help here.
    (blames music school)
  2. lp rob1
    lp rob1 Modder
    14 Jun 2010
    ATM, ATI graphics cards hold the market. I recommend a 5850 as it's got the best performance/value.
    For the CPU, I'd say the i7 930, unless you're an AMD fan. Obviously the mobo will be needed to change. Because of the new triple-channel memory you will need new memory as well. Good thing you want to replace all of that!
  3. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Stick in a Titan Fenrir CPU cooler, bump up the overclock and buy a 5850/70.
    If you'd prefer a complete overhaul, get a i7 920 with a Titan Fenrir, appropriate motherboard and RAM (I'm no good at those parts so I'll let someone else recommend things) and get a 5850/70.
  4. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    Would love help in regard to a good motherboard/ram configuration * UK based *
    As for the ATi 5870 does anyone here use one of those within Star Trek Online/EVE Online, and could give their opinion?
  5. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    CPU: Intel i5 750 - £156.45
    http://www.scan.co.uk/Products/Inte...ld-45nm-Quad-Core-266GHz-8MB-Cache-95W-Retail
    MOBO: Asrock P55 Extreme - £106.40
    http://www.scan.co.uk/Products/Asrock-P55-Extreme-Intel-P55-Motherboard-LGA1156
    or
    Asus P7P55D-E LX - £113.45
    http://www.scan.co.uk/Products/Asus...DDR3-2200(OC)-USB-30-SATA-6Gb-s-SATA-RAID-ATX
    RAM: G-Skill 4GB 1600MHz DDR3 - £101.51
    http://www.ebuyer.com/product/180490
    Graphics Card: Sapphire HD 5870 1GB - £319.98
    http://www.ebuyer.com/product/199644
    The ASRock board had crossfire support & is cheaper than the Asus. However Asus is a more recommended manufacturer in general & the board has USB3 & Sata 6Gb/s support. Personally I'd go for the ASRock as crossfire provides a very attractive upgrade option.
    Total is £684.34 with the ASRock board & £691.39 with the Asus board (make sure you use the bit-tech & scan free delivery scheme for all memebrs with 20+ posts).
    Neox010 likes this.
  6. murraynt
    murraynt Modder
    6 Jun 2009
    Re-guarding the motherboard i would go for the
    Gigabyte UD3R
    http://www.scan.co.uk/Products/Giga...e-PCI-E-20-DDR3-2200-1333-SATA-6Gb-s-RAID-ATX
    A i7 930 processor
    http://www.scan.co.uk/Products/Inte...Hz-QPI-48GT-s-8MB-Cache-20x-Ratio-130W-Retail
    Or a 920 if you arnt overclocking over 3.8 ghz
    Ram 6gb mite be a bit excessive
    http://www.scan.co.uk/Products/plus...0-(1600)-Non-ECC-Unbuffered-CAS-9-9-9-24-165V
    There is also a guy selling a near new i7 and 6gb of ram on the forums for 230 pounds
    Reguarding the graphics card it wont really make much of a difference since it is so powerfull anyways
    This is if you want i7 if you want i5 the above setup is perfect
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    i7 will be out of your budget, I look at basic setups once a month usually for on here and a i7 would start at £700, but that is for a whole setup.
    i7 930 - £212
    Gigabyte GA-EX58-UD3R - £130
    Patriot Viper Extreme Performance 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz - £153
    XFX ATI Radeon HD 5870 "AVP Edition" 1024MB - £318
    Total of £813, so not too far out of budget. I play STO on my 5870, and it still lags, but this could be from my internet connection, as its usually fine but has been playing up for the last month. Saying that, I play Bad Company 2 and thats fine, so it's weird.
    Hope this helps :)
    Edit: Ninja'd twice!!
    Neox010 likes this.
  8. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    Spoke to her in charge and be going with your list Pete.
    Cheers for everyone's help, I just hope it goes together right.
  9. Bloody_Pete
    11 Aug 2008
    What PSU are you using?
  10. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    Corsair HX620 Modular
  11. Telltale Boy
    3 May 2010
