Scratch Build – Complete ⭐ Hi-Fi PC
Discussion in 'Project Logs' started by Božo Kaurić, 29 Apr 2020.
  1. Božo Kaurić
    Božo Kaurić What's a Dremel?
    25 Apr 2020
    Hi all!
    As someone who likes old Hi-Fi gear and collects old Sanyo Hi-Fi components, I decided to take one old Sanyo amplifier and integrate my computer inside of it. That way I can have my PC as a part of my Hi-Fi tower!
    I used standard desktop components I had in my PC, but my goal was to have the whole front completely functional, all the knobs and switches.
    I know this is not the top of the line PC, but it is my baby I have been using for years now and its still serving me great, so be gentle :)
    Original amp had to be gutted, and many modifications had to be made to the main shell. While I was at it, I also customized almost all the components inside, and made many parts out of copper and wood.
    Bottom part of the case had to be separate from top so I could fit original 1978 switches inside, and to make room for three hard drives. I separated bottom and top sections with one piece of hand cut copper plate (2mm thick). Purpose of copper is purely cosmetical, there is no special reason (heat etc) behind it. That plate sits on four steel feet with anti vibration rubber on bottom and top, painted in copper.
    Back plate is made one part from copper (where motherboard comes), and one part in wood (where graphics card comes).
    Since there is a serious height problem with that kind of case, I had to use PCI-Express riser to place graphics card horizontally and Noctuas low profile CPU cooler in order for everything to fit inside.
    Graphics card and motherboard both got a new paint job and wooden inserts.
    Front functionality, starting from left to right:
    - Top two knobs control fan speeds
    - Power switch turns on the computer
    - Green light for HDD activity
    - USB 3.0 port hidden behind a knob
    - 2 switches to turn on/off fans
    - 2 switches to turn on/off LCDs
    - Above switches - left LCD shows case temperature and the right one - CPU temperature
    - Largest knob is for volume control
    - below it, another USB 3.0 hidden behind a knob
    - Big red power light
    Outer shell has been made from scratch, using 1.5mm aluminum mesh and profiles. Top plate is hinged, so it is extremely easy to take a look inside ;)
    And finally, all the copper got a nice polished finish and the rest was painted in mat black.
    I hope you will like it as much as I liked working on it. It took me some time, but to me, its more then worth it.
    And don`t judge it by the old components... I worked with what I got ;)
    Have a nice day everybody!
  2. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Wow! blown away, this post answers my question in the last post :p
    Božo Kaurić likes this.
  3. Božo Kaurić
    25 Apr 2020
    And here are some "making off" pictures:
    Cheapskate and kim like this.
  4. Božo Kaurić
    25 Apr 2020
  5. Cheapskate
    13 May 2007
    Lovely work, and welcome to Bit Tech. :D
    Zappa's Autobiography is friggen' hilarious, by the way.
  6. Božo Kaurić
    25 Apr 2020
    Thank you, and thank you :)
    Yeah, Zappa is one of my favorite maniacs :D
  7. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    love the project.
    As you have learned with the first few posts, there are eagle eyed members who spend as much effort looking at the PC as the background objects.
  8. Božo Kaurić
    25 Apr 2020
    I always setup my photos with that in mind ;)
  9. Cheapskate
    13 May 2007
    :lol: We noticed that too.
  10. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Gotta love the easter eggs lol
    Lovin' the build!
  11. ciaognep
    ciaognep Minimodder
    10 May 2020
    I done something similar in my past but you work is superb. Hi hope all HI FI component was broken I hope
