Graphics How do I go about fixing a bad GPU bios flash?
Discussion in 'Hardware' started by kissinger, 20 Nov 2012.
  1. kissinger
    kissinger Minimodder
    6 Dec 2011
    Looking for a bit of expert knowledge before I get on with this. I flashed one of my 7970 bios to the GHz edition bios and then tried to flash it back, but it didn't work and now I've only got one working bios.
    How do I flash the broken bios back to factory condition? Do I just boot using my iGPU and a bootable usb and then type 'atiflash -f -p 0 oldbios.bin', making sure I've set my card to the broken bios first?
  2. rollo
    rollo Modder
    16 May 2008
    In theory you can use the second bios to reflash the first one there is no guarentee this will work though.
    Ghz bios uses higher than standard speeds not every 7970 will hit them safely, and a small reminder only reference 7970 bios can be flashed to ghz bios, if you have a even slightly custom card then the chances are your bios is not stock.
  3. kissinger
    6 Dec 2011
    My card is reference and the GHz bios worked fine on it. I just felt like flashing it back to the original bios because the GHz didn't offer any real advantages. The problem is that flashing it back didn't work and now it won't boot from that bios.
  4. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Are you certain you have flashed back the correct stock original BIOS?
  5. kissinger
    6 Dec 2011
    I'm as sure as I can be. I just used the standard command. I.e. 'atiflash -f -p 0 oldbios.bin'. It seemed to work but then when I tried to reboot it wouldn't.
  6. Parge
    16 Jul 2010
    I think he means, did you use the bios from the same manufacturer as the card?
  7. kissinger
    6 Dec 2011
    The first thing I tried was flashing it back with the original bios that I had saved when I flashed to the GHz bios, but that didn't work. Then I flashed it with a bios of a mate of mine who has the exact same card, but that didn't work either.
  8. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    If you have another GPU, boot from that one and have the 7970 in a lower PCIE slot and flash it that way.
    Dunno the switch for ATIFlash but it can be done.
    Techpowerup has a comprehensive list of bioses
    Sent from my GT-I9300 using Tapatalk 2
  9. kissinger
    6 Dec 2011
    I don't have another GPU but can't I just use iGPU on my 2500k?
  10. rollo
    rollo Modder
    16 May 2008
    The likely hood is your card is not reference at all despite what they may say and it has a custom bios hence every time you try to flash it fails. Even the same card may not have the same bios due to date of manufacture.
    I'd just go back to the ghz bios if I was you as you know it works.
  11. lysaer
    15 May 2010
    Yeah that should be fine, I'm fairly certain there is a switch in ATIFlash for doing certain PCIE slots.
    Which 7970 do you have?
  12. kissinger
    6 Dec 2011
    But I saved the original bios so I know it has to be the same one.
  13. kissinger
    6 Dec 2011
    Don't I just go with '0', which is the first slot by default? I only have one GPU installed (not counting my iGPU).
  14. kissinger
    6 Dec 2011
    Okay guise. Thanks for your help thus far. I tried flashing using my iGPU but this is what happened:
  15. Harlequin
    Harlequin Modder
    4 Jun 2004
    its a blank image - you need to rehost on another service (image shack maybe?) as postimage has embedded advertising and is blocked here
  16. kissinger
    6 Dec 2011
    Fixed image.
