Guide How to brush Aluminum
Discussion in 'Modding' started by The_Gnu, 31 May 2006.
  1. spivey
    spivey What's a Dremel?
    6 Jul 2006
    brushing aluminum
    When brushing larger pcs lets say a 4x4 sheet any tips on the guide setup ? thank you.
  2. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    You mean larger square plates?
    When brushing my larger plates, I did it in two steps. One half at a time. brushed from one side in to the middle and then moved the guide over to the other side and brushed in to the middle from that side.
    /GNU
  3. birddawg
    birddawg What's a Dremel?
    10 Apr 2008
    Aluminum Working
    Your project is really nice. Could I ask how you were able to cut such nice holes and what you used to round the corners?
    Thanks
  4. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I must say, this is a great How To.
    I do it in a slightly different way, but its similar.
    I attach the sandpaper to a table, which butts against a wall, and using the wall as a guide, i pull the alu across the paper.
  5. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    GUYS!!! The last post before today was in 2006!
  6. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    nothing wrong with reviving an old thread if there is still information to be had from it. slightly better than forming a new thread and asking the same questions all over again that may have been covered in the origional o_O :naughty:
  7. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    i agree there is nothing wrong with reviving this thread im my opinion it should be stickied as there are constantly people wondering how to get teh brushed look on alu.
    josh
  8. jhanlon303
    7 Sep 2006
    Yeah, I'm one of them! I found this quite informative even if it was before I joined BT.
    John
  9. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    LOL I didn't even notice. Although I did find it quite useful...
  10. Skullz350
    Skullz350 What's a Dremel?
    11 Nov 2008
    Beautiful work Gnu!
    I am doing a backsplash for our kitchen using 5052 Aluminum plate. It is a design from a company in Italy and since no one offers their products in the states I am doing it myself. See the floor/wall planks it at: http://www.metalborder.com/floor-wall.htm
    I will be using the 2", 4" and 6" strips at 36" instead of their 40". These are stacked with alternating brushed and swirled pattern.
    Had a question for you - - -
    What type sandpaper did you use? wet/dry metal?
    Having a hard time finding the clearcoat, lots out there but want to use something that has been proven to work- - you have a link to the one you use?
    Thanks again and sorry to ask something totally unrelated to modding boxes....but...:rock:
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Very nice guide :thumb:
  12. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    out in commercial industry we do a lot of "Grain matching" or "Brushing" When we fabricate units at my job we often have to match the grain to sheet metal.
    we use a combination of
    belt sander+straight edge
    or nylon bristle disks on a angle grinder. identical to those used to strip paint http://www.toolspot.co.uk/product/bluespot-paint-and-rust-remover-wheel-for-drills
    but wider.
    if it's a big sheet say a 4'x8' We can use a panel sander which is essentially a really wide belt sander where the work piece moves instead of the tool.
    Personally I've always used the paint stripping wheel above. very fast and easy.
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Your guide made the CaseModBlog today!
    I would have posted it sooner, but just recently heard about it. Congrats!:thumb:
  14. Guest-23315
    Guest-23315 Guest
    Its a great guide, even though its 2 years old!
  15. The_Gnu
    12 Sep 2005
    Wow, I thought this guide was forgotten an havn't bothered looking at it. Thx to you all and its nice to see that you guys can still find it and find it usefull.
    Thanks Skullz
    Im sorry for the late reply and I asume you already got the answere to your questions. But I'll answer them anyway incase someone else got the same questions.
    The sandpaper I used was normal dry sandpaper found among the paint shelfes in a hardware store. I don't know the real difference but I'm pretty shure it was meant for wood.
    I starte with 80-120-180-and fineshed of with 240
    Regarding the clear coat, I think i bought 3 different clear coats and tried out the one that woorked best. The one I chose was from designed for aluminium rims. But I think you should look for some clearcoat designed for automotives our outdoor ecuipment since they are probably the toughest.
    Thx a lot. Nice to see the log on other sites apart from this.
    Good luck with all your work
    Take care
    /GNU
  16. naresh3159
    naresh3159 What's a Dremel?
    19 Jan 2010
    Hey
    You have any ideas about how to achieve the same finish on a whole aluminium coil and not just a sheet? or is cutting the coil into sheets and then doin this process the only solution?
  17. stonedsurd
    11 Mar 2009
    Wire brushes + industrial roller? I saw it being done in a factory somewhere.
  18. naresh3159
    19 Jan 2010
    am wondering how would the sandpaper block move on the aluminium sheet if its clamped to those wood logs on the side? :S
  19. dryrice
    dryrice Zestious Knight
    8 Jan 2010
    Wirewool or you could use wet and dry paper
  20. The_Gnu
    12 Sep 2005
    I've never thought of it in that large scale, don't even know if it is possible with this method. Maybe you could fix the sandingblock and then feed the roll of alu beneath it several times instead of mowing the sandingblock over the alu. Would probably need some type of fixture created for the roll since I don't think it is easily done by hand. What thicknes of alu are you thinking of?
    That wood block on the side are not fixed. They are only clamped to the side of the sandpaperblock as a guide to help it maintain a straight line throughut the whole sanding process. The wood blocks are pressed agains the working bench while draging the sandpaper along the aluplate.
