Graphics How to save graphics card
Discussion in 'Hardware' started by Xir, 30 Mar 2015.
  1. Xir
    Xir Modder
    26 Apr 2006
    So...my graphics card died.
    I've cross tested it with two loaned ones and with a functioning card, everything is fine. (the first one I swapped it for was also broken, go figure)
    Anyway, I'd likt to try the "Oven Trick" to try and save the card. It's in a very old pc and the cheapest new PCIexpress cards I could find are still dearer than the entire pc. :D
    At what temperature and time should I bake the card?
    Best regards,
    Eric
  2. mrbungle
    20 Sep 2004
    Strip it, whack it in the oven @ 200 for 7-8 minutes and then stick the cooler back on.
    That said a replacement 2nd hand card would not be at all expensive.
  3. Xir
    Xir Modder
    26 Apr 2006
    I'll try...thx.
    Havent managed to find one <30€, which is the new price for a GF210 or a 5450
  4. mrbungle
    20 Sep 2004
    If you use eBay then there should be tons of options for that sort of money.
  5. Guest-44432
    Guest-44432 Guest
    Stick it in the microwave, it's sure to fix it! :D
    I do not take any responsibility for anything that happens...:D
  6. Xir
    Xir Modder
    26 Apr 2006
    Well, I hadn't hoped for it, but it actually worked :thumb:
    I probably should have taken off the VGA-extender, as it was cabled and melted a bit but the machine runs again.
    Unbelievable, Thx! :rock:
  7. Guest-17499
    Guest-17499 Guest
    Haha amazing, hadnt heard of this trick before
  8. mrbungle
    20 Sep 2004
    Good news :D
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    It uses the oven to "re-flow" the solder on the board, fixing any "dry joints". :dremel:
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    I picked up an 8800GT from the Marketplace for a fiver a couple of years ago. A quick bake had it and and running and it only recently died completely. Obviously this trick is not always going to work and of course left to long in the oven a pile of plastic is likely to be the result. But if you have nothing to loose then worth a try.
  11. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I've seen this trick done before but I always wonder why the components facing downwards don't just fall off when the solder melts?
  12. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Generally even melted solder can hold relatively large items in place as long as they're not nudged. Obviously trying to hang an entire GPU by melted solder is likely to fail but most smaller things stay due to the viscosity of the solder. (Viscosity may be completely the wrong word lol)
  13. mrbungle
    20 Sep 2004
    Yeah there is a balance of enough heat to get a decent reflow and ending up with a pile of surface mounted caps.
  14. theshadow2001
    3 May 2012
    I imagine it's surface tension that would hold parts in place. I believe liquid solder has a convex meniscus, demonstrating it's high surface tension properties.
    noizdaemon666 likes this.
  15. Xir
    Xir Modder
    26 Apr 2006
    I'm not sure it's really haeted to the melting point, ideally it would be heated to the point where annealing takes place but in a normal oven (and not knowing what solder was used) this is all moot.
    Just heat it and hope for the best. :rock:
  16. noizdaemon666
    15 Jun 2010
    That's the phrase I wanted! Have many reps :lol:
  17. theshadow2001
    3 May 2012
    lol. Yay points! :clap:
