i have a ?
Discussion in 'Hardware' started by Milky, 13 Nov 2002.
  1. Milky
    Milky What's a Dremel?
    2 Nov 2002
    i changed my thermal compound to some new **** now my cpu is reading 46 degrees C / 116 degrees F. is that good i was getting lower but that wont fry my proccessor will it
  2. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    Err.. what CPU? :wallbash:
    You should start worrying if it gets to around 60.
    Atm, you're fine.
    Isn't there a Hardware forum round here somewhere?
  3. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    moved to hardware... wooooosh
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    what did you have before and what did you replace it with?
  5. Milky
    2 Nov 2002
    its,
    i have a Amd Athlon Xp 1800+ I was getting around 35 Degrees C / 109 Degress F before that was with some generic radioshack heat sink compound - im using coolermaster thermal compound now. and getting around 48 degrees C / 118 degress F
  6. herbs
    herbs Nobody but us chickens
    7 May 2001
    Either the reading with the radio shack stuff was wrong or you have applied too much/little of the coolermaster stuff.
  7. Milky
    2 Nov 2002
    not sure
    i did apply a pretty good amount not like half the bottle but enough its makes a Square 1inch by 1inch
  8. Bursar
    Bursar What's a Dremel?
    6 May 2001
    There's a couple of tricks with applying thermal compund.
    Firstly, you need to remove the old compund from the CPU and the heatsink. I use acetone free nail varnish remover and cotton buds to do this.
    Then you want to spread a very thin layer of your new thermal compound across the top of the CPU core. It only wants to be about as thick as a sheet of paper. Using too much will actually increase your temperatures.
    Then fit your heatsink. Then remove your heatsink and check that there is a nice square imprint of thermal compound on it from the CPU.
    If so, reapply the compound and fit the heatsink. Job done.
    If you didn't get a nice imprint on the bottom of the heatsink, then either the compound wasn't applied evenly to the CPU, or your heatsink has a curved base. If the heatsink isn't flat, you'll need to lap it (plenty of guides on doing this exist on the net).
    You can then follow the steps again, and eventually you'll get a nice fitting heatsink that gives you reasonable temps.
  9. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    That really is the key right there! Just a paper thin layer and only on the Core. Should see you sorted with that!;)
  10. aurazes
    aurazes What's a Dremel?
    5 Oct 2002
    are these temps at full load or idle?
  11. Milky
    2 Nov 2002
    yeah thx
    i got it as thin as possible and stuck at one temp now. thx still running a bit sluggish but maybe in a few days of hard pushing it will start to wear itself in :) and go back to normal speed
  12. sjorel
    sjorel What's a Dremel?
    1 Nov 2001
    Re: yeah thx
    :confused:
  13. aurazes
    5 Oct 2002
    sluggish... not suppose to be.. whats ur temp now?
  14. Milky
    2 Nov 2002
    43 degress C / 109 degrees f wich is normal opc has been running for a couple of days now its actuall running normal now. i did have to much on it took more off and now its doing great
  15. aurazes
    5 Oct 2002
    cool u have pretty simular temps compared to me.. i get 42 idle..
