Scratch Build – In Progress I love rock
Discussion in 'Project Logs' started by stallo709, 26 Feb 2016.
  1. Vault-Tec
    30 Aug 2015
  2. stallo709
    stallo709 Minimodder
    8 Apr 2011
    thanks friend:thumb:
    like sugar:D
  3. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    This is a pretty sick build, love it! Dig the work/methods as much as the outcome :thumb:
  4. Cheapskate
    13 May 2007
    ^This. :D Your work is very unorthodox and fun.
  5. stallo709
    8 Apr 2011
    I try to build something new unconventional...I hope to succeed:dremel:
    is very funny for me it is a pleasure to do modding in this way.
    thank you all:rock:
  6. stallo709
    8 Apr 2011
    hi guys,It continues with the work.
    we clean the aluminum from paper residues
    many parts of this aluminum will be chromed at the end of the work.
    let's start with stabilizing the aluminum structure
    this profile in L will need to give support to the structure .
    Now we create the holes that will be used for homes plan
    continue...
  7. stallo709
    8 Apr 2011
    we model the excess wood with a chisel
    discard the machined part to make it smooth
    continue...
  8. stallo709
    8 Apr 2011
    Now we fix the front part of the structure with a profiled bar.
    every single bolt or screw you will not see at the end of work
    continue...
  9. stallo709
    8 Apr 2011
    support for the power supply
    the lower part is almost built.
    the next developments will be this:duh:
    ciao:dremel:
  10. stallo709
    8 Apr 2011
    hi guys
    it's time to start the two side sections using a protective varnish.
    I repeat the process three times
    After three hands, the result is very good
    continue...
  11. stallo709
    8 Apr 2011
    fold the two aluminum bars with the desired shape
    He begins to take the desired shape although we are still far
    temporary use of wood to support the aluminum structure
    ciao
  12. stallo709
    8 Apr 2011
    hi guys, I'm back here to go forward with this work.
    we start with the sawing of the wings ...
    the aluminum plate is always 2 mm.
    the wings will be composed of glass and aluminum.
    is a very complex project, I understand That it is still unclear what I intention, but give me another month or so and you will understand everything ...
    mdf.
    I will not explain in detail at this stage exactly what I will, but as you'll see in the next post will place the various pieces of MDF, and how will I complete the wings with the glass, and then graft them on the wood.
    the only sure thing is that I have already chosen the two colors for most of the houses, namely those below.
    you can tell a very complicated painting
    ciao!:rock:
  13. Vault-Tec
    30 Aug 2015
    ooo custom paint !
    I love both colours and the patterns in the second.
  14. Nexxo
    23 Oct 2001
    I is intrigued.
  15. amagriva
    amagriva Minimodder
    13 Jun 2009
    Adesso ho capito il nick! Parti forte poi vai in stallo :lol:
    Scherzi a parte i colori per le vernici sono bellissimi.
    Dai! Sprint finale per il mod of the year!:)
  16. GeneralFun
    GeneralFun Lurker with tools
    24 Feb 2014
    Unique technique! Looking forward to seeing your concept come to life!
  17. stallo709
    8 Apr 2011
    very special painting:hip:
    I hope so:thumb:
    in stallo ci sono andato molte volte...:D
    i colori sono molto particolari si.
    magari! ma sono molto indietro, e poi non so francamente se questo lavoro possa rientrare in quella categoria...vediamo dai.:thumb:
    modding particular:dremel:
    thank you all:rock:
  18. stallo709
    8 Apr 2011
    we start with the news...
    for power supply support
    I tested the arrangement with an old power supply
    most of the cables will be placed below
    Now we block the top
    let's start with assembling the back
    flames and even flames:dremel::D
    in the coming weeks we enter the heart of the process with various coatings that this work will have.
    like guitar picks:naughty:
    little
    average
    great
    Now use imagination...:idea:
    ciao bit-tech:clap:
