Case Mod - In Progress Icy Blue Angel II
Discussion in 'Project Logs' started by snef, 6 Jun 2014.
  1. snef
    snef What's a Dremel?
    18 May 2014
    some Cables done, like it clean like that
  2. Thorn
    Thorn Gaijin Studios
    19 Feb 2004
    love it
  3. Kerroin
    Kerroin What's a Dremel?
    7 Jul 2014
    Wow man, that's a very clean case!
    I love the color scheme!
  4. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    Great photo's of a beautiful build, The Fuzzy would approve!
  5. snef
    18 May 2014
    Thanks Guys
    Leak test
    90% of cables are done
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Money! :jawdrop: Snef, is there a 240 rad in the bottom compartment? Kinda hard to tell from the pics.
  7. montymole
    montymole Rigid Tubist
    24 May 2010
    I can say yes for Snef its a 240 rad for sure
    And So nice to see this with the coolant in it so nice love it as always :)
  8. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    looks great!
  9. snef
    18 May 2014
    Thanks
    yep Bart,Monty is right a 240 on bottom and a 360 on top
    i really like rad outside of the case
  10. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    That must be an awfully slim rad, or those compartments are thicker than they look in pics!
  11. onevoicewild
    20 Dec 2014
    Probably an EK - Coolstream PE - I have some 480's and they cool like crazy. I like how the Rad is hidden. Very special case.
  12. Parge
    16 Jul 2010
    Wow, that is absolutely jizztacular.
    What you thinking in terms of lighting?
  13. snef
    18 May 2014
    thanks
    we can put a 34mm thick rad with the cover or thicker if you remove the cover
    for lightning....
    fan are blue led to keep the color accent
    and will have white led strip
  14. montymole
    24 May 2010
    I put mine on the inside but It was purely aesthetics as it was working better when I was test fitting and looking at the options, bottom line you can use a number of ways if only 1 GPU then a thicker rad can be used either 240 or 360 as you can have it with the 360 at the bottom as I did :)
  15. Mike Silver
    Mike Silver What's a Dremel?
    19 Mar 2014
    Realy nice build!!! I love how clean it looks.
    I was just wondering why all you fan are extracting and the case doesn't seem to have a lot of ventilation exept from the fan's mount. So from were does your rad take some fresh air?
  16. montymole
    24 May 2010
    the case has very large hexagons as the vents top and bottom and has plenty of airflow even with quiet fans :)
  17. Mike Silver
    19 Mar 2014
    Sorry, I misspoke. My point is that all the fan are extracting air and the only ventilation on the case are the ones were the radiator and fan's are mounted. So with the side panel on the air as not a lot of ventilation to get some air in.
    It might only be for an aesthetic purpose and I must say it look's really nice!
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Love the colours and clean lines! :thumb:
  19. snef
    18 May 2014
    Thanks
    I've made a lot of testing with fan in exhaust, intake , 3 in and 3 out all in and all out
    and never see over 2c difference,
    I choose aesthetic first, I hate the back of a fan, its just so ugly
    and don't see any real improvement, I put them all to see the best looking side :thumb:
  20. snef
    18 May 2014
    some asked me for some photos with panel ;)
    final shots really soon
