A/V IEM/in-ear recommendations
Discussion in 'Hardware' started by marlowdrummer, 2 Nov 2013.
  1. marlowdrummer
    marlowdrummer Minimodder
    24 Nov 2008
    OK audio guru's, need some advice.
    Looking for a new set of IEM's or in-ear 'phones. Budget of around £100. Can probably go to £100 for a replacement amp as well if the Fuji is going to be an issue, but only if really needed.
    These are to be used daily for the walk to work, all sorts of music from punk, metal, Scottish folk, dance and audio books --- don't ask, I have weird tastes :)
    Not a fan of full size/hipster headphones, bleargh!!!
    Currently running Sony MDR-EX300, powered by a Sansa Clip+ and a Fiio Fujiyama.
    So, recommend away and ta in advance.
  2. Mister_Tad
    27 Dec 2002
    I'm delighted with Shure SE215s, and they would comfortably come in under budget too as a bonus.
    marlowdrummer likes this.
  3. Tangster
    23 May 2009
    +1 on the Shures. I wouldn't even bother using them with an amp, they sound fine straight from a Clip.
  4. marlowdrummer
    24 Nov 2008
    Sounds like the Shures are the way to go.
    Thanks guys :)
  5. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    if you can stretch to them, UE 900s are half price direct from logitech right now, 169 instead of 330. i got some at full price back in august and they've been fantastic.
  6. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    I really like Panasonic's in-ears. The buds are at an angle that seems to fit more ergonomically than other headphones I have tried.
    [​IMG][​IMG]
  7. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    Bit late, but I'm a self-confessed Sennheiser fan so I'd go for IE-80s - all-round they're pretty decent, my music tastes are almost as varied (heavy metal, classic rock, musical theatre, jazz, easy listening, acoustic).
    That said, sound is an extremely personal thing, so if in doubt, try and get to some stores and try a few out - I've always been pretty impressed with Sennheiser all the way from the CX-300 to IE-80 but YMMV :)
  8. skunkmunkey
    skunkmunkey Minimodder
    15 Jul 2007
    Love my IE80s too and they are really solidly built too.
  9. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I have Ajays four - I think they are awesome, and I have comply memory foam tips on them, which I also think are awesome.
  10. GeorgeStorm
    16 Dec 2008
    Another Shure e215 user here, my first 'decent' IEMs and I like them.
    Come with 6 different tips (3 sizes and in 2 materials), and although I think ideally I'd want something between two of the sizes they're still quite comfortable and sound good :)
  11. skunkmunkey
    15 Jul 2007
    I like the comply tips too but they disintegrate so quickly it would cost a fortune to use them all the time...
  12. Margo Baggins
    28 May 2010
    Have had them in circa 2 months at the moment and they are just as good as when new, maybe this will change. First time user! I don't put my iem's in my pocket though, Ikeep them in a little pouch in my work bag, maybe this will prolong life?
