News Intel-Micron gives NAND some TLC
Discussion in 'Article Discussion' started by julieb, 18 Aug 2010.
  1. julieb
    julieb What's a Dremel?
    12 Aug 2010
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Sounds like MLC should be called BLC now.
    Or DLC. OH WAIT.
  3. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    i htink this is good becasue memory is still too expensive
  4. Burdman27911
    Burdman27911 What's a Dremel?
    26 Mar 2007
    I wonder what the performance hit will be. SLC NAND is quite a bit faster than MLC... so I assume there will be some sort of penalty to increasing the layers again. Certainly interesting though, and I look forward to higher capacities at the same price points for less-performance driven parts.
  5. Gareth Halfacree
    4 Dec 2007
    Could explain why they're going for cheap SD cards and other non-performance-critical applications, rather than SSDs.
  6. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    You can't use TLC or triple-bit flash cells in an SSD - the lifespan and write performance will be atrocious.
    Looking forward to some 25nm MLC goodness though :)
  7. Xir
    Xir Modder
    26 Apr 2006
    Hmmm, has Mirrorbit* ever caught on?
    *AMD/Fujitsu** dual bit cell.
    **formerly FASL, then Spansion
Tags: Add Tags
