News Intel updates microcode to block H87/B85 overclocking
Discussion in 'Article Discussion' started by Gareth Halfacree, 25 Jul 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Seems a bit off that Intel is dictating what people are allowed to do with non Intel MoBo's even if they do make the chipset. Then again if your buying a K series why would you scrimp on a lower spec MoBo ?
  3. rollo
    rollo Modder
    16 May 2008
    Sounds like a safety issue. The cheaper boards are most likely designed for stock speeds only not over volting and clocked to the hilt.
  4. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    I would only consider getting a Z87 if I was going for a K-series in any case.
  5. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    I find this a little disappointing. Considering how high people can overclock intel CPUs on stock voltage (or the stock heatsink), a cheap board should be able to get to at least that point. You can save a considerable bundle of cash by overclocking with a cheap board. While you might not reach the best performance, that's what you get for not buying something better. The stupid thing is with Intel's decisions, people are building a system that is overkill for their needs without overclocking to begin with. So it's either pay good money for products that don't need overclocking, or pay less money for products that do need it but can't.
    But, I haven't bought an intel processor myself since I think 2005 (though I did get an intel-based netbook in 2009) so I don't really care either way.
  6. Kruelnesws
    Kruelnesws What's a Dremel?
    7 Jan 2012
    I personally have a z series board. So this has no effect on me! Even if you get a mobo that is not a z87, with the new block in place, couldn't you just go to the manufacturers website and download an older version of the bios as a workaround? Or do you think they might tweak some of the older ones?
  7. Tangster
    23 May 2009
    Intel, party poopers of the overclocking world.
  8. schmidtbag
    30 Jul 2010
    Seeing as how I'm not much of an Intel or Windows user anymore, I'm not 100% sure on this but I don't think it's that simple, because I think newer versions of Windows keep the microcode up to date without warning. I'm sure it is actually possible to reverse the microcode but I guess my point is something is bound to set it to something newer again whether you like it or not.
    In Linux anyway, you have to go out of your way to tell the OS to upgrade the microcode. It isn't hard but it isn't something you just simply know to do off the top of your head either.
  9. Corky42
    30 Oct 2012
    While Windows can update the microcode AFAIK Microsoft only do this for critical bugs, so in theory you could just use a older BIOS ROM.
    I cant see this affecting many people, i mean how many people have a K series on a B85 or H87 chipset ?
    it's not like they are stopping people from OC'ing via the FSB, they are just stopping the B85 or H87 chipset from going higher than the default multi when using K series CPU's.
    EDIT: some sites are even saying this is Intel fixing something that wasn't intended, a bug, all be a good one :)
  10. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    The knock on effect of no competition at the top end :-/
  11. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Yup, the sad truth is that even a locked Haswell is still a better performer in both performance and power than anything AMD has unless you do a lot of multithreaded work.
  12. Corky42
    30 Oct 2012
    Am i missing something hear then ? because AFAIK all previous K series CPU's were only supported in high end MoBo/Chipsets.
    The only reason Haswell K's could be used in B85 or H87 chipsets was because of a workaround developed by MoBo manufactures.
  13. GeorgeStorm
    16 Dec 2008
    You could run k chips in low end boards, as far as I'm aware at least.
  14. TimB
    TimB What's a Dremel?
    19 Sep 2006
    So I assume this only effect LGA 1150 (Haswell) chips?
  15. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    I wonder if Intel are getting a lot of warranty requests due to overclocking becoming so popular.
    They could be trying to limit their potential replacements. Since I doubt they have a valid way to prove if a chip has been overclocked.
    Besides, build a ten foot wall and someone will inevitably build an eleven foot ladder
    Sent from my GT-I9505 using Tapatalk 2
  16. rollo
    rollo Modder
    16 May 2008
    Intel dont make the motherboard first and foremost, Only the chipset thats on the boards is from Intel. Mobo manufactures would still have to implement this to the chipset.
    The haswell K chips are not designed for the B85 and H87 chipsets last I checked most of those boards did not even support the newer chips.
    Also not sure why you would buy a £40 board a £200 cpu thats like buying a ferrari and sticking some crappy tires on it.
  17. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Not everyone buys a high end CPU to overclock and not everyone who would like the higher end clocks of a top end CPU need the bells and whistles which often give top end board there price tag. My Dad is one of these such users. 2600k, basic motherboard = does exactly what he wants it to :)
  18. Corky42
    30 Oct 2012
    I cant think of any reason to buy the more expensive unlocked CPU if you wasn't going to overclock it :confused:
  19. Guest-16
    Guest-16 Guest
    Just to clarify our position on this:
    1) ASUS hasn't yet received any official documentation or instruction from Intel.
    2) It's a fact that already shipping and channel products won't be affected and you can still get the unlocked BIOS from the product pages.
