Hardware Investigating 3D Screens
Discussion in 'Article Discussion' started by Baz, 27 May 2011.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
    Fizzban likes this.
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    Could we not strike a balance with IPS and a refresh rate of 80/90/100Hz?
  3. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Shutter glasses alternate frames, effectively halving the visible refresh rate. Try dropping the refresh rate of your current screen down to 40/45/50Hz and you'll see why anything less than 120Hz is going to be a problem.
  4. Xir
    Xir Modder
    26 Apr 2006
    Ehmmm, no.
    This part implies that TV screens, using fast IPS or VA panels (they're 3D capable) are superior to monitors, and tests just don't show this.
    A 24" TV is cheaper than a 24" IPS monitor, and they've got the same digital input and resolution now. We'd all have one, right?
  5. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    If what Acer say is true about their 27" 3D then I might be convinced to ditch my current monitor later this year ...
  6. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    Isn't there a difference in dot pitch though?
  7. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    If a movie needs all these bells and whistles then it's probably not worth watching.I know I get engrossed in a film if I'm enjoying it.
  8. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    I'd rather they all went back to making 1920x1200 resolution screens.
  9. tigertop1
    tigertop1 What's a Dremel?
    23 Apr 2009
    One point in favour of these 3D screens is that they run at 120Hz. 2D viewing improves a lot when you use it versus a 60Hz monitor. I have had two 3D screens now, A Samsung which was OK but would not run Blu-Ray unless one reset it to 60Hz. The Acer GD245HQ is simply the best screen I have ever had and it is pretty well pefect for gaming and watching 3D DVDs
  10. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Ok, I'm officially getting tired of this 3D week thing... what's next, shark week?
  11. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    As far as 3D goes for monitors it is well behind the Real 3D TV technology that companies like LG, Samsung and Philips (to name a few) are already producing. Since I can plug a PC in via a VGA or ideally HDMI port and have happily done so on a 42" screen with good results, then I would have to say monitor manufacturers have some serious catching up to do.
  12. DbD
    DbD Minimodder
    13 Dec 2007
    Personally I don't agree that colour is a major problem with these 3D TN panels - the LG W2363D is fine colour wise, deviation is low enough and colour gamut is high enough. Viewing angles mean you might loose a bit if it wasn't your primary screen but it is my primary screen so not a problem. Sure we always want better but the colours aren't bad, particularly if you use it for games which aren't true to life - it's not like you are trying to photo edit with the monitor.
  13. Grape Flavor
    Grape Flavor What's a Dremel?
    23 Sep 2009
    Excellent article. People can blast 3D all they want but the problem in the end is the displays - you have to wear shutter glasses and the screen itself is poor quality. These are not inherently unfixable concerns.
    Wait a few years until we have auto-stereoscopic displays with excellent color and all this "3D is a worthless gimmick" stuff is going to be looked back on as stuck-in-the-past nonsense. Only those with 3D-blindness will continue to defend such a position.
  14. Kris
    Kris Lord Lolwut
    6 Jun 2008
    and who cares about 3d anyway? it's just a gimmick :p
  15. FelixTech
    FelixTech Robot
    12 Jun 2009
    Isn't the saying 'making the whole greater than the sum of its parts'? I hope Viewsonic aren't publicly stating that their products provide less performance than you'd expect from their parts >_<
  16. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    Ah yes - here's a true 3D killer application for the gamer demographic - viewing mammograms.
  17. lp rob1
    lp rob1 Modder
    14 Jun 2010
    I thought that the frame rate at which a game is considered 'playable' is 25 fps, and that most movies run at 30fps? So 60Hz refresh rate is pretty useless? As the image is actually changed every 2 refreshes / the screen has to wait for the image to change. I never really understood that.
Tags: Add Tags
