Case Mod - In Progress InWin Toù "Carbon Luxury" MOD fINISH
Discussion in 'Project Logs' started by MathModding, 28 Apr 2015.
  1. Cheapskate
    13 May 2007
    -And a ton of other stuff, because it's the only Tou I've ever seen modded. :D
  2. MathModding
    MathModding What's a Dremel?
    23 May 2014
    This is the door of coarsely cut! Carbon 2mm thick.
    Still many cuts above work, let fastening lugs has to make on the top
    [​IMG][​IMG]
  3. MathModding
    23 May 2014
    Soon the end for my mod
  4. MathModding
    23 May 2014
    That is what patience and rigor allows for
    Alu 1.5mm, drill, jigsaw, milling, precision files.
    [​IMG][​IMG][​IMG]
  5. MathModding
    23 May 2014
    Hi all,
    my carbon door for my mod "Carbon Luxury" on INWin Toù carbonized frame.
    [​IMG][​IMG][​IMG]
  6. montymole
    montymole Rigid Tubist
    24 May 2010
    Awesome work gone into this :)
  7. Cheapskate
    13 May 2007
    ^Should be lighter by about 20 pounds too.:D
  8. MathModding
    23 May 2014
    Thanks ;-)
  9. MathModding
    23 May 2014
  10. Farsan
    Farsan What's a Dremel?
    1 May 2014
    LOL
  11. MathModding
    23 May 2014
  12. MathModding
    23 May 2014
  13. MathModding
    23 May 2014
    Hi guys,
    tubing finish!
    [​IMG][​IMG][​IMG][​IMG]
  14. MathModding
    23 May 2014
    Block homemade ;-) for my tubing.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  15. MathModding
    23 May 2014
    Well here we go
    Start the mold for the cache alim 100% carbon.
    I have to give him the most nikel can look to reduce finishing steps in once the mold made.
    Initially, the power supply cache is gross, I will have to cut carbon to give it the desired shape. But that was after ^^
    I admit from the unknown and have a little apprehension for the price that it costs me ^^
  16. MathModding
    23 May 2014
  17. MathModding
    23 May 2014
    Hi guys,
    My final loop finish. With pass through the back MB.
  18. MathModding
    23 May 2014
    Beginning carbon molding. Preparation of the mold.
    1st step: Sanding to 600 and then scrub BELGOM ALU by hand.
    2nd stages: the first layer of "release wax" and allowed to dry before wiping.
    [​IMG][​IMG][​IMG]
  19. Cheapskate
    13 May 2007
    The initial investment is brutal, but now you can make an entire case from CF.;)
    loop looks great.
  20. MathModding
    23 May 2014
    Thanks :thumb:
