Scratch Build – In Progress Iron Revenge II (By Herodj) - Sleeving!
Discussion in 'Project Logs' started by Herodj95, 25 Apr 2012.
  1. Herodj95
    Herodj95 What's a Dremel?
    9 Sep 2011
    Thank you dietje! :D
    yeah, to do this "spines" i've get some inspiration from many cases and mods! ;)
    up very soon! :rock:
  2. Herodj95
    9 Sep 2011
    UP!
    I have get 3 steel plates whit 0.8mm of depth! I have choise this depth beacause i'm going to do some work on they! ;)
    the first plate is for the back of the case.... Draw the cuts!
    start to cut! :dremel:
    Finish result!
    there i'm going to install 3 switch like this
  3. Herodj95
    9 Sep 2011
    the second plate is for the lateral panel of the case...
    What i want to do!
    I'm very impatient to start to cut!!
    At first time i want to do easy cuts!
    And now....
    see behind...
  4. Herodj95
    9 Sep 2011
    Ok, i'm in a good point but i haven't finish!
    i must work hard with files to many letters...
    the panel before the filework!
    finish!
    and there are the 2 finished plates! (lacks a plate)
    Ok, now that's all!!
    I appreciate your comments :D
    Bye bye! :)
  5. The_Crapman
    5 Dec 2011
    That's some nice detailing :thumb: Especially considering you were using a cutting disk!
  6. Herodj95
    9 Sep 2011
    thanks crapman.... cutting wheels aren't particulary suitable for little engraving but the files resolve this problem! :D
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Very nice work.. subbed for updates!
  8. Herodj95
    9 Sep 2011
    thanks mark :)
    In the evening new updates!
  9. eeced
    eeced My finger is in the fan
    26 Mar 2007
    Love scratchbuilds, they constantly inspire me to try one myself one day. ATM my wallet and my neighbours wouldn't appreciate me turning the apartment into a mod-shop. :)
    Those spines make me think of an old russian train, dunno why. Like it :)
  10. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    Looks real great actually, like the scoop at the top, Raven look-a-like! :)
  11. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    your cuts are clean, very good !
  12. Herodj95
    9 Sep 2011
    yeah, the scratch builds in my opinion are the best choice of modding because you can set all meausure without case limits... so, scratch build sometimes are more expensive than case modding but by this you can have more satisfactions! ;)
    yes, this case is inspired to predator and raven case :)
    Thanks thegyufi! :thumb:
  13. Herodj95
    9 Sep 2011
    added 2 sheets... the top (we have seen it previously) and the background....
    at the background i have do simple cuts for air flow!
    it's time to fix all..!!
    engraved sheet...
    the back...
    and with rivets, the background!
  14. Herodj95
    9 Sep 2011
    Sleeving
    now i'm going to do sleeving!
    no nils sleeving but paracord!!
    the victim of sleeving :)naughty:) is an enermax revolution 1050w
    my purpose is to avoid the heatshrink ... for this i'm hoing to melt the paracord sleeve on the cable... that's the result! The melted paracord it's very strong but difficult to spread on the cable!
    i'm going to do this process on 24 cables...
    and on the 6 vga pin...
    :clap::clap:
    And that's all now!!
    See you soon! :D
  15. stallo709
    stallo709 Minimodder
    8 Apr 2011
    fantastic work very nice DJ:clap::clap::clap:
  16. The_Crapman
    5 Dec 2011
    I just got one of those PSU's. I was planning on re-sleeving them, but in their stock form they do not like bending one bit, so looks like i'll have to :-(
  17. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Great looking front, can't wait to see it all painted. And I must say, your workplace is awesome. It's a very very small balcony right? Kudos to you for doing all this in such limited space :)
  18. Herodj95
    9 Sep 2011
    Thanks you Stallo! :thumb:
    yes the enermax cable are more strengt than other PSU... but in my opinion this is better because the cable "stay together" :thumb:
    Thanks malobee, that's right, i work in a small balcony, 70 cm of width and i can't work perfectly but i try to settle down :)
  19. Herodj95
    9 Sep 2011
    so, sorry guys for my another absence! :wallbash:
    In this time i've worked on the other side panel, another steel panel!
    after the meausuring time i proceed with the cutting!
    removing the tape... so the glue is still here :wallbash:
    diluent time :D
    now the sheet is clean!
    and next i use sandpaper and water...
    don't use diluent in plastic cup... that's the result :jawdrop: :rock:
  20. Herodj95
    9 Sep 2011
    after the cleaning i proceed with the real work....
    but before i bought some things! :D
    at the first i'm going to create some holes to fix the panel at the frame!
    and this is what i want to do!
    This drawing is purely aesthetic...
    and now start to cut!
    finished work!
    and there are the 2 side panels :D
    so, i've try to do a test with a led strip!
    what do you think??
    Bye bye :D
