Case Mod - In Progress LAN-Can - First build
Discussion in 'Project Logs' started by Gobi, 3 Jan 2013.
  1. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    Love the idea,
    really hope you pull it off,
    will be brilliant
  2. Gobi
    Gobi What's a Dremel?
    2 Jan 2013
    Slow, but steady update.
    I've been designing the cooling and trying to figure it out how to fit those 2x240 radiators inside.
    Problem solved with right angle 90 degree PCI Express riser, with that i get GPU pointing down -> more space to radiators.
    All the parts are 3mm aluminium, partly welded together. I'm saving the logo on the other side by cutting only lower part of the side. That will serve as intake, to the bottom of the can i will install 200mm fan, which will push the air out. That will need a little guide to push the hot air away from the intake area.
    I think i may have gone a little too BIG with this kind of setup... It's getting little tight fitting the other parts.
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    If you want to use 200 mm fan to push air in the back, the the best solution would be to use PlayStation 3 (fat) fan.
  4. Gobi
    2 Jan 2013
    I'm not familiar with PS3 fan, will check out. Air flow direction is not yet solved. The best way, or how I think it is, is to pull cool air first to radiators -> then circulate it within case -> direct it to exhaust.
  5. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Here is the link .
    As you can see,it's made to blow in any side direction. That would be the best solution for your build.
  6. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Why don't you cut little air slits behind the rad? Then you could suck in cool air and blow it out through the rads.
  7. Gobi
    2 Jan 2013
    You mean above that fixing plate, which is on the side? There is logo on that spot, i want to save it.
  8. vils
    vils What's a Dremel?
    4 Jun 2006
    *Sigh of relief*
  9. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    These can's are selling for £95 on antique sites
    Source
  10. Gobi
    2 Jan 2013
  11. elAwesome
    1 Nov 2012
    Now imagine the value if a watercooled high end pc in this antique case ;)
  12. Gobi
    2 Jan 2013
    I sent the drawings for laser cut this morning, here is x-ray view of the radiator housing.
    Next on to-do list is to order Bitfenix Spectre Pro 200mm fan and design the piece which will serve as finger protector/bottom of the case.
    I have to come up with some cool logo/drawing to cut to that piece.
  13. Gobi
    2 Jan 2013
    Look what the cat dragged in:
    2 of his homies and slides for the can! :)
    Just as i thought, they fit in perfectly:
    There's only room for the back cover, which will be made of aluminium also.
    I'm going to mix paint to match the current color (Vintage red;)) and paint all parts that will fit outside with it.
  14. Axoxenon
    Axoxenon Do it right the first time
    28 Dec 2012
    Looks great! Gonna look great when you get your stuff from cutting :D
  15. Gobi
    2 Jan 2013
    Little text form update:
    I did some calculations and noticed that i can barely fit an mATX motherboard. That's what i'm heading for now, will see if i have to regret this later. :)
    Parts for the watercooling unit have been cut, now i'm waiting for them to arrive. I'm not much of a welder, so i'm leaving that part to my older brother.
    I've been searching small round TFT display, plan is to fit it in the cap. It has to be smaller that 1.2" in diameter. Things to show from it: water temps, cpu temp, clock, date, etcetc.
  16. Gobi
    2 Jan 2013
    Bitfenix Spectre Pro arrived today, it fits perfectly to the bottom. A little push and it locks itself to the sides. Now i can draw fangrills to that monster.
  17. elAwesome
    1 Nov 2012
    ...as if the fan was made to fit the can.
    Cool!
  18. Gobi
    2 Jan 2013
    Here are parts for the radiator housing.
    Can't wait to get this assembled! :D
