Logitech MX Duo
Discussion in 'Hardware' started by Sowler, 7 Oct 2003.
  1. Sowler
    Sowler What's a Dremel?
    22 Mar 2002
    GloucesterShire
    Just bought the above and am very pleased with it apart from the fact with the keyboard the extra buttons don't quite work properly. If i want to assign like the 'my home' button to a website it doesn't like it. I assign it in the config program but nothing happens when i press the button. Does anyone know how to fix this or had this problem as well.
    Cheers
    John
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Leeds UK
    are you using the logitec software?
  3. Sowler
    22 Mar 2002
    GloucesterShire
    Yes I am
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Norfolk, UK
    Got the newist stuff from the website or are you still using the stuff that came on the CD?
  5. Sowler
    22 Mar 2002
    GloucesterShire
    Its ok now thanks jus did the sensible thing and re-installed the itouch software. All workin fine now thanks.
    Cheers ppl
    Sowler
