Motors lost v 11 car tax form
Discussion in 'General' started by pranks7er, 30 Jun 2008.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    ok my car tax (uk) is up tomorrow i went looking for my v11 application form and i cannot find anywere, can you request a replacement or do you need to have this form im led to believe all you have do is bring reg certs instead and ur previous disk as well as other standard docs im i right??
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    You should be able to take the V5. Failing that ring the DVLA for your renewal reference number, then do it online.
  3. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    i think theres another form you fill in, its got a similar name, like v111 or v11a.. but its essentially the same as what they send you, but you have to fill it in yourself, just fill it in in the post office queue
  4. Krikkit
    21 Jan 2003
    Do it online? I can't remember what you need, but I'm betting you don't need a v11...
    [edit]Here's the page. Sounds like you only need your V5. :thumb:
  5. pranks7er
    25 Dec 2002
    ahh brilliant thanks
