as per title really i want a modular psu around 400w. all the ones i can seem to find are at least 600w or above, i don't especially need such a powerful and don't want to pay for all that extra headroom My pc specs are: AMD 5800k stock 3.8ghz Asrock FM2A75M-ITX motherboard Crucial 8GB 1866Mhz Ballistix ram Toshiba 1Tb hard drive and its all in a coolermaster elite 120 case which is why i want a modular psu, im just using a cheap 450w right now and its a mess of cables i dont really need plus i want to upgrade to a 270x or 280x soon so i dont trust a crappy psu to handle that
This 450w Corsair RM series unit is fully modular or there's the semi-modular Corsair CXM or CSM units.
Silverstone ST50F-P is the only fully modular < 500 Watt PSU I've found so far. All the others have the 24 + 4/8 ATX-connectors permanently attached. It's also only 140mm deep, i.e. has a standard ATX-PSU size of 150x140x86mm
Seasonic X-400FL if you can get it somewhere (Scan says it's EOL for some reason). http://www.servercase.co.uk/shop/pc...sonic-psu-400w-x-400fl-fanless-apfc-ss-400fl/
