Apple Macbook battery woes
Discussion in 'Software' started by Dizman, 28 Dec 2006.
  1. Dizman
    Dizman What's a Dremel?
    6 Jul 2006
    So my poor, beloved macbook is refusing to acknowledge the existence of its battery. Up to this point, I've had absolutely no trouble with it, and I can't figure out what would cause that. Any ideas?
  2. Firehed
    15 Feb 2004
    Sounds strange... maybe the terminals are dirty? Does it run of the battery anyways, or just totally not function if unplugged? I'd check for any sort of corrosion (though I've never heard of it happening on laptop batteries) and just reseat it and see if that works.
    Since I'm noticing you're in Vermont :rock: if you're not too far out of South Burlington, the Small Dog Electronics store might be able to figure it out. If not, I'd give Apple a call and see if they can come up with anything. Though I'll bet they tell you the same thing I just did, and then have you send it in if that doesn't work.
  3. Dizman
    6 Jul 2006
    I am near small dog, and I dropped it off today. I just wanted to make sure I wasn't missing anything stupid before I got somebody to look at it. But a week with no mac? *crawls into fetal position*
  4. bennifer
    bennifer What's a Dremel?
    26 May 2004
    Mine did that, was using it and it came up with a no battery installed thing. A few days later my hard drive burned out, along with the hdd controller on the logic board... dead macbook! hoorah!
