Case Mod - In Progress Macintosh Atom(?)
Discussion in 'Project Logs' started by vils, 29 Nov 2009.
  1. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Macintosh gets an upgrade :D!
  2. WhatTheTech
    WhatTheTech Macmodder Addict
    18 Dec 2012
    Definitely excited to see where this goes!
  3. vils
    vils What's a Dremel?
    4 Jun 2006
    Internet connection reestablished (for a while) and phone problem solved.
    Here are the chisel work in progress:
    Sanding almost finished:
    The back of the case was also 'cleaned' from various plastic ridges and stands. The blue paper represents a sheet of perspex that will be sanwiched between the case and a inner piece of aluminium. The perspex will be illuminated with leds so that the connecters have a glowing edge around them.
    I/O layout planned:
    How everything will be placed inside the case depends in part of how deep the connecters are going to be. I'm scouring the web for panel mounted connecters. I've found a few so far but they are a bit too big (deep).
  4. morgansk
    morgansk I've got wood
    12 Jan 2013
    Nothing better than turning an Apple into a real computer. :D
  5. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Fixed. :D
