Wii / Wii U Mario Kart Wii
Discussion in 'Gaming' started by M_D_K, 13 Apr 2008.
  1. M_D_K
    M_D_K Modder
    3 Apr 2002
    Lets get some battles on the go
    PM me your Wii codes and i'll add you etc...
    Its awesome fun :D
  2. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I'll have it by Monday but I'll be damned if I can figure out where to get a wii friend code from. Nintendo seriously need to figure out their online stuff.
  3. M_D_K
    M_D_K Modder
    3 Apr 2002
    its not your friend code its your mario code there different.
    Just go into the game and then to the online bit and friends and it'll be in there :)
    its good been playing all night :p
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Do you need to get the wheel, or can you play without?
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    You don't need it, but you get the wheel with the game anyway.
    Will be picking this up tomorrow.
  6. M_D_K
    M_D_K Modder
    3 Apr 2002
    As yoda said you get the wheel, it does make it a little easier to play the game as your holding onto something bigger then a remote lol and the trigger on the back is easier to keep pressed to hold onto them shells :D
  7. Netflow
    Netflow What's a Dremel?
    12 Apr 2008
    GAh to the rest of the world getting this before me in Canada. Cannot wait to get this game over here.. Question: Are you finding yourselves using the steering wheel or playing without it?
  8. K
    K 528491
    31 Oct 2001
    The wheel made my arms ache to be honest. The classic controller forces analogue stick usage (grrr they're too far over) but was better in general. I'm sure the best setup is the Gamecube controller as the analogue stick on it is awesome but I don't have one here to try it out. Doh. Still, fab game.
  9. sjhujh
    sjhujh Minimodder
    1 Feb 2008
    The nunchuck and wiimote setup works pretty well, i found the steering to be a bit hard to use and gimicky, wish they had the option of buying it with out the wheel, would have cost a tenner less probably....
  10. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I don't like using the wheel tbh, the wiimote and nunchuck combo works best for me.
  11. M_D_K
    M_D_K Modder
    3 Apr 2002
    whats the wiimote numchuk combo ??
    i always use the wheel
  12. Major
    Major Guest
    Exactly why I bought 2 wireless GC controllers, also bought them for SSBB. ;)
  13. sjhujh
    sjhujh Minimodder
    1 Feb 2008
    Nunchuck + Wiimote combi controls....
    A = go
    B= Powerslide
    Z= Use powerup
    C= Look back
    Analogue Stick= steering
  14. Netflow
    12 Apr 2008
    Hmm interesting.. How long before the wheel started to give you aches?
  15. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Ten minutes and the novelty wore off.
  16. Major
    Major Guest
    Depends how fit your arms are.
  17. M_D_K
    M_D_K Modder
    3 Apr 2002
    Might give that a go later :)
    Novalty is yet to ware off lol and i was playing it for about 4hours last night lol 1 handed eating your dinner is a bit of a mission doubt i can manage that with the numchuk combo
  18. Daniel114
    Daniel114 What's a Dremel?
    9 Sep 2007
    Im not sure wether its just me, but I always feel the wheel stops turning before it should
  19. Johnnyp87
    Johnnyp87 What's a Dremel?
    16 Apr 2008
    I have only played using the wheel and have found that it can be a tad unresponsive as to what your doing at times.
    I might have to give it a go with the control and nunchuck and see if it works better for me.
  20. Major
    Major Guest
    Grab a cheap GC Controller.
