Case Mod - In Progress Mods By Donnii - NZXT Manta
Discussion in 'Project Logs' started by Donnii, 11 Apr 2016.
  1. Donnii
    Donnii Mods By Donnii
    15 Jul 2015
    So i needed to make something to my woman and she had some colors she want and a small case so this time i will build a cool little NZXT Manta case moddet to fit a M-ATX and a **** load of water cooling from Aquatuning.de
    Lets start with the Specs:
    Motherboard: ASUS X99m-WS
    CPU: i7 5820k
    RAM: 32GB Kingston Predator 2800Mhz
    GFX: MSI GTX960
    SSD: Not decided yet
    NIC: Intel 10GBps X520
    Cooling parts
    Alphacool NexXxoS XP³ Light - Plexi - Intel/AMD
    Alphacool Eisberg screw cover with springs
    Alphacool D-RAM Cooler X2 Universal - Plexi Black Nickel
    Alphacool D-RAM Cooler X2 Universal - Acetal Black Nickel Version
    Alphacool NexXxoS ST30 Full Copper 280mm
    Alphacool NexXxoS ST30 Full Copper 240mm
    Alphacool VPP655 - single edition
    Alphacool Eisbecher D5 150mm Plexi
    Aquatuning AT-Protect Clear can 5000ml
    Aquatuning AT-Protect-UV Crystal Blue can 5000ml
    Alphacool HardTube 16/12mm plexi clear 80cm - 4pcs*
    Fans:
    2 x 140mm Noctua Industrial PPC-2000 PWM
    3 x 120mm Noctua Industrial PPC-2000 PWM
    More info will come!!
    /Donnii
  2. Donnii
    15 Jul 2015
    Let the modding begin :rock:
    /Donnii
  3. Donnii
    15 Jul 2015
    I got some work done and all i need in there is ind place now :)
  4. Donnii
    15 Jul 2015
    So today i got the Alphacool parts for the system :) Or atleast some of them :) so we did get some work done! This system is for my woman so its obvious that she helps build it :) she mounted the waterblocks on the motherboard and RAM and installed the Radiators in the system.
    More is coming up tommorow :)
    /Donnii
  5. Arboreal
    21 Jan 2011
    Great work, mATX in a Manta is inspired - it's TOO big for ITX.
    Surprised to that with its clothes off, the Manta is a regular cuboid case :lol:
    Looking forward to see where this is going; like the X99 including cheeky m.2 action with watercooling to follow.
  6. Donnii
    15 Jul 2015
    Thank u :) This case just should have been made for a M-ATX to start with!
    And yes the inside is a bit cheap :)
  7. Donnii
    15 Jul 2015
    Just a short update from today. We just got the parts from Aquatuning today so we can get going with the build, fittings, PWM spiltter, pump mounting and so on :)
    /Donnii
  8. Donnii
    15 Jul 2015
    Today i got a nice package from Noctua with the fans and the Chromax ruber things :) So i got some things done today.
    /Donnii
  9. Donnii
    15 Jul 2015
  10. Donnii
    15 Jul 2015
    The Machine has been running for some time now and is super low noise just as we wanted, now i need to make some parts to get going with this one.
  11. Praelia7or
    Praelia7or What's a Dremel?
    16 Apr 2016
    NZXT make a number of fantastic looking cases with this method! Quite unique as a manufacturer in doing that though I think. My current case is an NZXT M59 which is actually a simple 'box' but the exact same insides are used in a number of different cases, and it's been excellent tbh!
