Case Mod - In Progress MONO -( COMPLETED )-
Discussion in 'Project Logs' started by BERNARDO, 11 Sep 2016.
  1. BERNARDO
    BERNARDO Bernarndo mod chop
    1 May 2014
  2. BERNARDO
    1 May 2014
    rad placement
    i made psu cover a simple neat look. the cable were sleeved
  3. BERNARDO
    1 May 2014
    placing my ssd at the back of the motherboard
  4. Vault-Tec
    30 Aug 2015
    Stunning work. The motherboard is simply gorgeous.
  5. BERNARDO
    1 May 2014
    lets make a loop
  6. BERNARDO
    1 May 2014
    thanks Vault-Tec
  7. BERNARDO
    1 May 2014
    12mm acrylic tubes and fittings by barrow
  8. BERNARDO
    1 May 2014
    bending
  9. BERNARDO
    1 May 2014
  10. BERNARDO
    1 May 2014
  11. BERNARDO
    1 May 2014
    thank you fractal design , teamgroup, asrock, ren sleeve for making this mod possible
  12. BERNARDO
    1 May 2014
    final pic
  13. Vault-Tec
    30 Aug 2015
    Wow that cooler mod is also awesome. I didn't know the Kelvin was G1/4. Looks brilliant too man great work !
  14. Cheapskate
    13 May 2007
    Nice and clean! I love what you did with the faceplate.
  15. BERNARDO
    1 May 2014
    thank you
  16. user_name
    user_name What's a Dremel?
    3 Mar 2016
    I am curious about how you mounted that IO cover. Did it fit perfectly on top of the IO blocks or how did you mounted it? I am planning to print one for my Mainboard IOs. Currently I thought about using the mainboard holes next to the IO panel to mount it. But it looks like you got a better Solution.
  17. BERNARDO
    1 May 2014
    just cut a bit of acrylic and desired thickness match the level on the other part then use double sided tape to fix it there
