Modding mounting a slimline CD-Rom - what kind of screws\where to buy?
Discussion in 'Modding' started by r3Q, 6 May 2012.
  1. r3Q
    r3Q Minimodder
    31 Jul 2002
    Hey there guys,
    I have been building a carPC for a while, and im looking for some kind of bracket with hardware\screws for my slimline sony optiarc AD-7690H optical drive.
    basically its going to be mounted in the dash, and im going to have to dremel out some plastic and do some finesse work - the thing im trying to figure out is how am i going to cradle this thing? i am planning on building a flat area or shelf from ABS to sit the cd rom on, but i have no idea what kind of screws there are available for this thing.
    im going to bring it to lowes - but i doubt they have screws this small, and as long as id need them to get through 1\8" abs and screw into the drive.
    my plan is to mount it above the screen im going to use. i bought one of these;
    http://www.idotpc.com/TheStore/pc/viewPrd.asp?idproduct=804&idcategory=74
    im going to affix that to the 'shelf' im going to make.
    but i still cant figure out where i can get some of these screws.
    does anyone have a link for them? preferably in the us?
    thanks guys!:rock:
  2. r3Q
    r3Q Minimodder
    31 Jul 2002
    nothing?
    nobody knows what screw size\thread these drives use? :(
  3. Big Elf
    23 Apr 2009
    I've got a 7690H mounted in a Silverstone FP58 and used M3 screws to fix the drive into it.
  4. Attila
    Attila still thinking....
    22 Feb 2008
    I've used five slot loaders and my preferred method is foam backed double sided tape. This stuff is super strong and if you want the drive to be removable, then make a caddy for it that can be mounted with screws.
  5. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    Used expanding foam round one dvd drive.. bagged the drive in small baggy first .. then squirt..
    trimmed off excess.. seems to be working still :)
  6. r3Q
    r3Q Minimodder
    31 Jul 2002
  7. Big Elf
    23 Apr 2009
    It's the same model as I have and mine definitely uses M3 screw mounts.
    Edit: Just had another look. I'm an idiot. I've mounted the drive in a drive bay that uses M3 screws. The internal screws that hold it in the drive bay are smaller and possibly M2
  8. r3Q
    r3Q Minimodder
    31 Jul 2002
    haha okay. possibly m2? *sigh*
  9. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    I have the SFF-8552 specification for "form factor of 5 1/4" 9.5mm and 12.7 mm height optical drives".
    PM me your email address and I will send it. It is a 54 page pdf that will give you all the dimensions including this one:
