Msi motherboard
Discussion in 'Tech Support' started by Daniel Lieberman, 16 Jul 2023.
  1. Daniel Lieberman
    Daniel Lieberman What's a Dremel?
    16 Jul 2023
    I have a msi x 58 pro mother board I replaced the power supply than the computer only gives off an amber light and no post
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Did you reconnect the 4/8pin CPU power connector in the top left? Did you reconnect any power cables for graphics cards? Was the power supply the only thing you disconnected?
    The_Crapman likes this.
  3. The_Crapman
    5 Dec 2011
    Sounds like EPs cable problem as above, but why was the PSU replaced? If the old one died, might have killed something else in the process.
