Well, Here is a lip spring test ,Nothing is glued down ,Its just a test. Click here to watch liptest-50 Also,I made the thoat on the upper teeth this week. Gary
This is looking fantastic, i really cant wait to see this attached to a case, as that is going to be one freaky case. I am really enjoying this most unique mod, keep up the good work
Thanks scifi3018 Some grabbed shots from videos Changing the bite 2nd floor servos Waxing teeth Running MonsterMakers's Foam Brushing in foam Finishing teeth with dental lathe Gary
my sister just came in and said "ugh wtf is that" sufficed to say, after i explained to her, she called you a geek
Wow...simply amazing i cant wait to see how this will make it into the case That last part in the video was scary!
Looks great and when its mounted on a desk with a monitor its going to look extraordinary, you have a great amount of skills and the last update... amazing But are you going to "stain" the teeth of the mod? Such as red ink for blood, a tint of yellow or a slight brown tone to the teeth and the gums? That should finish them off very well... and having bright white teeth on a "monster" isn't so realistic right?
well from what I hear he works as a dental lab tech so I guess he gave all his monsters a good talking too and now they have good teeth
If you look at the original teeth, they were nice and staind. However in the last pictures update he mentioned that he was changing the bite o fthe teeth, so he started over. I can only imagine that he will redo the teeth in a similar fasion... dental technician or not
utterly utterly scary!! just wondering if its possible to make a tongue with some wires and tubes inside like u did the lips? then it can kinda bend in a realistic way?
Yes , i sculpted tongue and molded it and casted in silicone last week ,I was not happy with it . So, I made it out of dental acrylic . This tongue is controlled my the jaw no servo. The realistic way I would need 3 or 4 servos ,Im running out of room in the skull ,Im using 16 servos now. Thanks gary
