Scratch Build – In Progress -=My Brutal Frets on Fire Guitar/Keytar=-
Discussion in 'Project Logs' started by dadde, 24 Oct 2007.
  1. dadde
    dadde What's a Dremel?
    22 Dec 2003
    sweden
    Ok, so this is the story so far:
    After playing Frets on Fire about 2 times i decided that this game realy deserved a desent guitar (keytar).
    To try if it would be possible to use microswitches instead of keys i slayed an old wireless keyboard.
    This is what happend to it:
    Its horrible I know. But its just an experiment so see if it was possible.
    And it was.
    I would have used this wireless keybord controler if the range had not been realy awfull and if it had been possible to push more than 2 buttons at the same time.
    But the test was a succes anyhow and my wife liked the look of it so I gave it to her.
    And so it was time to go keyboard hunting...
    I know the people that works in a lokal PC-shop so I went there to ask.
    30 minutes later I had in my hand a flat USB-keybord, an PS2 kayboard and 3 bags of LEDs - total kost $0 - they are very friendly here in Sweden.
    Before it went to the gallows I tested what combinations that would let me hold down all 5 frets and pick at the same time.
    A D G J L and ENTER worked like a charm.
    Messure and write down what combinations eatch button that you want to use.
    But I want somthing more than just plane keys to push on this guitar so I made this litle thing
    It enables me to use the same button to light a LED and write out the right letter.
    Its very easy and basic; 3 4066 curits, 6 bc547 and some resistors. But it does do the job nicely.
    Its hooked up to the keybord controler:
    Anyone know what I'm up to? ;)
    This thing makes the leds fade out:
    Its 6 capacitor and some resistors, It makes the LEDs fade out when I relese the button but still light up instantly when the button is pushed.
    Alot of wires
    Now its time to make a guitar/keytar!
    A 12mm chipboard (I think it is called in english) "Spånskiva" here in Sweden.
    Can anyone guess the guitar that inspired me?
    Time to do some serrious cutting!
    Bewere of my jigsaw skills :D
    Atleast they are somwhat alike.
    Time to let enter the sandman
    Hush little baby, dont say a word
    Better indeed.
    It still need some sanding but I'll have to do that by hand.
    Now it need some holes for the buttons
    That was'nt to hard
    Now some space to put the electronics in.
    Dang! Thats nice! Well its not going to show later anyhow.
    Of with his neck!
    Stay tuned (haha I made a joke) for more...
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    U.S.
    wow, that looks really great. you may be able to make a business out of this ;)
    keep up the great work
  3. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    UK
    A worthy controller indeed!
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Wisconsin
    not bad
  5. kenco_uk
    28 Nov 2003
    Hurst Green, Halesowen, UK
    Rockin'!
    I'd love to see this working.
  6. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    AUS
    that looks great
    I had started to make one of these but stopped when i found out guitar hero 3 was going to be on the wii.
    GlovePI should do all the work for me
  7. ledbythereaper
    ledbythereaper What's a Dremel?
    2 Jan 2007
    Inside your intertubes
    Guitar Hero 3 for PC is going to make all this hard work seem kinda pointless.. but on the otherside you'll have a sick looking controller :p
  8. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    Melbourne VIC Australia
    Awesome mod :), I think after you finish this one you should make one out of clear acrylic, then the leds fading in and out would look brilliant, top job your doing, well done.
  9. dadde
    22 Dec 2003
    sweden
    The saga continues
    Oooo you know how to push my buttons (or make them anyhow)
    8mm Plexi
    21*18mm pieces
    1mm spacing, some CA-glue to keep the heads on buttons stay put
    Epoxi to strengthen the buttons
    Frosty buttons
    drilling, drilling, drilling
    aluminum foil...
    To make the light from the LEDs spread even
    Painting...
    Hotgluing the buttons to the guitar
    Gluing the top to the midle
    mmm, hotglue...
    Top to bottom; Glue everywere!
    Sanding, sanding, and more sanding
    Plastic Padding PP100 body filler
    More sanding
    It does get a bit dusty
    Hooks to hang the neckstrap from
    And some spray Plastic Padding
    More to come...
  10. dadde
    22 Dec 2003
    sweden
    Thanks for the feedback!
    The wheight of the guitar is at this moment 1923g or 1,9kg.
  11. mr_carl
    mr_carl What's a Dremel?
    2 Jul 2007
    Norrköping Sweden
    Exelent work
  12. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    Vantaa, Finland
    Looking sick! Very nicely done :)
  13. dadde
    22 Dec 2003
    sweden
    2:nd layer of body filler
    Sanded down
    3:rd layer of body filler
    Sanded down and time for 2:nd layer of Plastic Padding spray
    PP Spray done
    400 papper to make the PP spray smoother and let the paint stick
    Paint
    Primer
    Primer done
    1000 paper
    Smooth
    Remember always to clean everything before its painted
    First layer of black
    2:nd layer
    3:rd
    4:th
    Next week it will be done...
  14. Morphine-Kitty
    Morphine-Kitty Dead account.
    22 Apr 2007
    127.0.0.1
    Looking awesome! Really good job so far.
  15. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Hyde Park
    That's pretty darn impressive. well done!
  16. thermalnightmare47
    thermalnightmare47 What's a Dremel?
    18 Sep 2006
    Marietta, GA
    wow thats awesome.....and i can't believe you did that with chipboard i figured you would use plywood instead partially because of chipboard's bad rep at falling apart...but awesome nonetheless i want one...:)
  17. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    Brescia - ITALY
    Simply mad!!!! :rock:
  18. ZenX
    5 Aug 2005
    Vantaa, Finland
    I think you should clearcoat it..
  19. dadde
    22 Dec 2003
    sweden
    5:th layer of black
    1:st layer of clearcoat
    2:nd clearcoat
    3:rd
    4:th
    Guess the motive...
    More will come later this week
  20. macroman
    macroman The One
    3 Sep 2001
    U.K.
    Hurry up already :D
    Nice work:dremel:
