A/V New headphones
Discussion in 'Hardware' started by Tangster, 13 Dec 2011.
  1. Tangster
    23 May 2009
    York, UK
    Currently a bit bored with my Denon AH-D2000's so I'd like some suggestions on a new set(as a little xmas treat).
    Must be:
    -Closed
    -Not sennheiser
    -Circumaural
    - Less than £300
    Ideas?
  2. GrameSmith
    GrameSmith What's a Dremel?
    12 Dec 2011
    Sony MDR-XB700, try this one. i hope its well for you.
  3. Tangster
    23 May 2009
    York, UK
    No suggestions at all?
  4. bagman
    bagman Minimodder
    18 Apr 2009
    Swedish but in Suffolk
    Erm.. the denon AH-D200 is basically the best headphones for that kind of money. Are you using a proper headphone amp?
  5. Tangster
    23 May 2009
    York, UK
    I'm using a Xonar DX with a Sony TA-FE370 amp(with a Fiio E10 for uni).
    Hmm. I may just save the money for IB-E then, or a 256GB SSD.
  6. bagman
    bagman Minimodder
    18 Apr 2009
    Why are you bored of them? what kind of music do you listen to?
  7. Tangster
    23 May 2009
    York, UK
    Not really more of an upgrade itch, new headphones is far easier than delving into watercooling.
    I listen to a lot of orchestral music, vocal music and some dance/trance/dnb. Not so much rock, metal. Very little jazz.
    I haven't really gone out at all the last term at uni, yet still had a reasonably well paid job...so I have money left over.
  8. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i think you'd be better off asking this on head-fi tbh :/
  9. Katty123
    Katty123 What's a Dremel?
    2 Nov 2011
    You can try AKG K272 HD Closed Back Headphones. They cost about £130 and seem to meet your needs.
  10. Elton
    23 Jan 2009
    California
    MDR-V6. It's bright on the midrange, but it's cheap and pretty bulletproof. Really cheap actually.
  11. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    Watercooling is far more interesting and you get to build a cooler, quieter pc.
    Headphones important though. I use them a lot.
  12. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Belfast
  13. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Glasgow, but my heart is in Dunwall..
    Not Sennheisers? £300 buys the HD650, I've had mine for about a year, can't fault them...
  14. Tangster
    23 May 2009
    York, UK
    They just don't fit right and whats the point of £300 worth of audio quality if your ears hurt after a couple hours or they slip from your head when you move?
    I'm probably going to put the money towards Ivy Bridge or a new GPU instead.
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Near Baff
    You need soft cotton wool because clearly you have a delicate head.
  16. docodine
    docodine killed a guy once
    10 Feb 2007
    Denver
    The HD 650 is very comfortable once it's broken in, open though.
    How about some of Shure or Ultrasone's higher end closed cans? At the high end, closed headphones aren't as common as closed, but they do exist.
    How about new pads for your D2000? Jmoney makes quality replacements, they will change the sound.
    If you like Denon, there's always the D5000 and D7000 :p
